Read Picasa keywords
dave80
Post by dave80 »
Can XnViewMP read keywords written by Picasa?
I would like to use Picasa and XnViewMP to help me cull my photo collection. I would like to use Picasa to go through a folder and keyword photos I don't want with the keyword "delete". I would then like to open the folder in XnViewMP, select the "delete" keyworded photos and delete them.
The reason for doing it this way is I have used Picasa for a long time and don't want to delete any photos I have edited with it so the first stage of my culling process can only be done with Picasa. Some of the time I shoot jpg & raw but have Picasa set to only show jpgs. When deleting jpgs I want to also delete the raw and any companion files (.xmp, .pp3 etc.) but Picasa can't do that. XnViewMP can delete companion files and I have set it up to do so.
I think I have everything worked out and setup except how to get XnViewMP to read the "delete" keyword on a folder by folder basis as I add them in Picasa. Can anyone help please?
Re: Read Picasa keywords
dave80 wrote: Fri Oct 08, 2021 12:41 am Can XnViewMP read keywords written by Picasa?
the keywords are in sidecar right?
dave80
Post by dave80 »
xnview wrote: Fri Oct 08, 2021 7:39 am
Hi Pierre. No, the keywords are in the jpgs. Here is an example.
ok, keywords are readed by XnView MP if settings>Metadata - Import XMP subject is enabled
dave80
Post by dave80 »
xnview wrote: Fri Oct 08, 2021 9:38 am ok, keywords are readed by XnView MP if settings>Metadata - Import XMP subject is enabled
That has worked. Thank you very much :)
