Video metadata columns in browser list view
metal450
Post by metal450 »
It's super useful that Video metadata can be shown in the Info->Properties pane (i.e. width, height, duration, frame rate, bit rate, encoded date, format). Would it be possible to also provide these as columns in the list view? Especially on Linux, where none of the common file browsers have this (i.e. Nautilus, Nemo, Dolphin, etc), this would make video organization significantly easier.
Thanks in advance! :)
Re: Video metadata columns in browser list view
ok, i'll check if it's possible easily
metal450
Post by metal450 »
Thanks!
metal450
Post by metal450 »
Hi Pierre,
Did it turn out not possible? Anything I can do to help get this in?
metal450
Post by metal450 »
Did you determine this is not possible? You mentioned you'd check into this, 1 year ago.
yes sorry but many things to do before...
eMeM
Post by eMeM »
It would be very useful to have size info concerning video files, e.g.:
settings/browser/thumbnail/labels tab./custom label/video>height/video>width
or something like that.
Regards
metal450
Post by metal450 »
Just checking in as another year has elapsed (2 in total). Any chance of taking a stab at this? :)
metal450
Post by metal450 »
BigCheese
Post by BigCheese »
I have been organizing/tagging a lot of video files through XNView lately, and I've really felt the lack of the ability to sort, filter, etc based on this kind of metadata. So I'd also love to see these added.
Dbaeco
Post by Dbaeco »
Yes agreed, it is a great video manager, and showing a list view / thumbnail info with video metadata such as framerate & resolution would be very helpful. :D
Thanks.
