Negative values are not retained after pressing Write button.
1. Select thumbnail then menu: Tools>Metadata>Edit GPS data...
2. Enter negative value for Latitude or Longitude and press Write button.
3. Open Edit GPS data window and the negative values are positive and Map shows incorrect location.
Macbook Pro
MacOS Big Sur Version 11.6
XnView MP MacOSX
Version 0.99.1 64bits (Sep 23 2021)
Edit GPS Data
Edit GPS Data
Re: Edit GPS Data
This problem is supposed to be fixed in XnView MP 0.99.4. Please check and confirm the bug fix here.
