XnView 2.50.2
XnView 2.50.2
Dear user,
XnView 2.50.2 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 82EDE39222D75428027EFF32F168D9868998ACBC5D3A12E085604A8CB3B2AD7D
XnView-win.zip: F890583CD61B6D55A74A2BD75A710D466809FCD31442D213201CB35A253FE029
XnView-win-full.exe: F28E1873A4F934E37D7D6637446C55183F4C82DCCDE0647B29606CAD08D2928E
XnView-win-full.zip: EECBF258C3E442F001B555CE1FEC1CF5E86FF5B3F24EA3EC8C88002CB333B19F
XnView-win-small.exe: 3A2E4C32A5A579E5005ACBEEAEC0C4D1678E6C59FC18E8F1F172C8890B2FE55B
XnView-win-small.zip: D094C5864FEDD642C108ECF3A4A6599E242D83ED888C5249E2ADB67DA0E8ED4D
____ 2.50.2 Changelog
* Labels & tooltips can crash
* PNG crash
____ 2.50.1 Changelog
* Browser size not restored - viewtopic.php?f=36&t=42207
* Dialog always on Screen #1 - viewtopic.php?f=35&t=42147
* Context icon - viewtopic.php?f=34&t=42232
* NConvert: multiple -canvas & bgcolor
* NConvert: -jpegtrans - viewtopic.php?f=36&t=41826
* NConvert: -canvas longest 220mm - viewtopic.php?f=57&t=41812
* NConvert: jpegtrans exif & keepfiledate - viewtopic.php?f=57&t=42203
____ 2.50 Changelog
* APNG crash - viewtopic.php?f=36&t=41803
* JPEGXR RGB10
* CR2 orientation problem
* Ghostscript 9.54
* Recoil
* GEM vulnerability - Thanks to Michael Heinzl
* NConvert: -use_org_quality problem
* jpegtrans not written for NConvert - viewtopic.php?f=36&t=41826
* NConvert: -text_font name percent - viewtopic.php?f=57&t=41811
* NConvert: -canvas shortest/longest - viewtopic.php?f=57&t=41812
____ 2.49.5 Changelog
* Ghostscript detection
* TIFF - viewtopic.php?f=35&t=41136
* HEIF plugin - viewtopic.php?f=36&t=41104
* Old versions of ghostscript not recognized
* NConvert: -use_org_quality - viewtopic.php?f=57&t=41397
* NConvert: multiple text lines - viewtopic.php?f=57&t=41358
____ 2.49.4 Changelog
* Ghostscript 9.53.x
* GPS & file date - viewtopic.php?f=56&t=40971
* TIFF Security vulnerability (Thanks to Michael Heinzl)
* NConvert: -levels2 - viewtopic.php?f=57&t=40490
* NConvert: -resize supports cm/mm/inches
* NConvert: -autodeskew fixed
* NConvert: -noholder to disable %$ chars - viewtopic.php?f=57&t=40820
____ 2.49.3 Changelog
* Convert 16 to 256 colors - viewtopic.php?f=36&t=39421
* Disable ESC to close tabs - viewtopic.php?f=35&t=17078
[General] EscToCloseView=0
* Select file from search results & switching mode - viewtopic.php?f=34&t=40063
* Title empty when recurse - viewtopic.php?f=36&t=39979
* Resize - viewtopic.php?f=35&t=40248
* Slideshow: Order of files - viewtopic.php?f=56&t=40087
* Fortis Mag fix
* NConvert: -wmsize watermark percent size - viewtopic.php?f=57&t=38754
* NConvert: canvas size in inches/cm/mm - viewtopic.php?f=57&t=39361
* NConvert: replace_color - viewtopic.php?f=57&t=39769
* NConvert: -temperature added
____ 2.49.2 Changelog
* Problem with Ghostscript 9.50
* PDF font problem - viewtopic.php?f=36&t=39662
* CR3 - viewtopic.php?f=35&t=39478
* .sld must use 'Recurse' setting - viewtopic.php?f=35&t=39330
* GIF loop - viewtopic.php?f=36&t=31689
* PAM CMYK
____ 2.49.1 Changelog
* TIFF 16bits greyscale
____ 2.49 Changelog
* SQLite 3.29.0
* NConvert: greater_than/less_than condition - viewtopic.php?f=57&t=39147
* PSD: Error when writing metadata - viewtopic.php?f=57&t=39137
* Export - Problem with RGBA - viewtopic.php?f=36&t=39044
* Capture - viewtopic.php?f=36&t=38934
* Left/Right F11 to open fullscreen on Left/Right monitor
* Create multi file & folder with '.' - viewtopic.php?f=36&t=39008
* # to comment line in .sld file
* Multipage create: Check if output filename exists
* Slideshow crash when using animated GIF - viewtopic.php?f=36&t=38902
* XIM format import added
* Change timestamp must not use 12h format - viewtopic.php?f=36&t=38702
* GIF not played correctly in Slideshow - viewtopic.php?f=34&t=38303
* CVE - https://github.com/apriorit/pentesting/ ... ugs/xnview
* NConvert: -unsharp
* NConvert: -exposure - viewtopic.php?f=57&t=39136
* NConvert: -colorize h l s
* NConvert: Remove EXIF orientation -exif_rotation - viewtopic.php?f=57&t=38648
* [Rename]/TemplateStart, position of number in template - viewtopic.php?f=34&t=38568
* CVE-2019-12151
* ShellEx: 'Convert...' & input fields
