XnView: MP 0.99.0 64 Bit
OS: Windows 10 / 64 Bit
On searching pictures for example by keyword (knowing there is only one picture in the folder),
the dialog box lists this picture (path\name, but tells: Found 0 Files. So you can't display this
picture in resulting searchfolder.
By the way, if there are more than one search results, the value is wrong by 1.
I think this behaviour is new for version 0.99.0.
Guenter
(Edit) As tested in VirtualBox Ubuntu 20.04.3 LTS I found the same bug ...
Count Error
Re: Count Error
This problem is supposed to be fixed in XnView MP 0.99.1. Please check and confirm the bug fix here.
