XnView MP 0.99.0 doesn't show X3F-Files
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderators: XnTriq, helmut, xnview, Dreamer
michael_
Post by michael_ »
i'm running XnView on actual OpenSuSE-Tumbleweed-Linux. Everything was fine till today:
Today i updated my older 0.98-version of xnview mp to version 0.99.0. It starts as usual, but now it doesn't show X3F-Files, produced from Sigma-SD14, SD15, SD1M-cameras. The older versions didn't have this problem, thy showed the X3F-pics.
Is this a bug or a feature? ;-)
Would be very nice, if XnView 0.99.0 could be brought to the same functions as the earlier versions.
Thanks a lot,
bye
Michael
mpbac
Re: XnView MP 0.99.0 doesn't show X3F-Files
Post by mpbac »
I am having a similar issue but in a Mac version.
viewtopic.php?f=62&t=42344
right, this version use new RAW processor so i need to check...
As workaround, you can disable it in xnview.ini
RAWUseLibRaw=false
michael_
Post by michael_ »
xnview wrote: Mon Sep 20, 2021 9:00 am :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
thanks, with this workaround it works again.
I guess the new libraw will be more powerful. Where can I track that this X3F issue is no longer present by default?
Bye
Michael
is fixed in next 0.99.1
This problem is supposed to be fixed in XnView MP 0.99.1. Please check and confirm the bug fix here.
michael_
Post by michael_ »
thank you for Your fast response.
In XnViewMP 0.99.1 the problem is partially fixed. Photos from a Sigma SD1Merrill are shown perfect, while Photos from a Sigma SD14 are not shown, trying to view ends with a error "Error opening file".
For demonstration-purposes i have copied two pics to my website. As this a raw-pics, the are pretty big... Both files are o.k. I tested them in the Sigma-Raw-Developer Sigma Photo Pro 5, V 5.53. Download them via "Right-Click" and "Save as".
You can find them on
https://michelsburg.eu/diesunddas/diver ... w/SD1M.X3F
and
https://michelsburg.eu/diesunddas/diver ... w/SD14.X3F
The SD1M-File works perfect, the SD14-File doesn't.
By the way, i tested some gifs. In 0.99.0 they didn't run as loop. Now they work perfect too.
Good work. Thanks a lot.
Bye from Bavaria/Germany
Michael
do you have a preview in browser?
michael_
Post by michael_ »
i have made jpgs out of the original-x3fs in half of the original size and placed them in the same folder:
https://michelsburg.eu/diesunddas/divers/xnview
Bye
Michael
Sorry but what is the problem? You can't view these files? no preview in browser?
michael_
Post by michael_ »
the problem is, that xnview shows the x3f-files from Sigma SD1M perfectly, but doesn't show the x3f-files from the SD14. Both, SD1M and SD14, are DSLRs from Sigma (https://www.sigmaphoto.com).
In earlier versions of xnview the pictures of both cameras worked without problem.
Bye
Michael
michael_
Post by michael_ »
:D :bugconfirmed: :D
This problem is supposed to be fixed in XnView MP 0.99.4. Please check and confirm the bug fix here.
