0.99.0 - JPEG XL Export - AutoRefresh does not work
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
masterjp
Post by masterjp »
First thank you for the latest XnViewMP 0.99 with many good changes and improvements!
In the new JPEG XL export window you can activate autorefresh, but nothing will get refreshed, if I move the slider or the small up and down arrows for the compression level.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill
OS: Windows 10 Pro x64 (latest updates) | XN-View (latest stable version) |XnViewMP (latest stable version) | XnConvert (latest) | Adobe Photoshop Elements 2022 & Elements XXL 9
Re: 0.99.0 - JPEG XL Export - AutoRefresh does not work
This problem is supposed to be fixed in XnView MP 0.99.1. Please check and confirm the bug fix here.
