Each page of converted PDF saved with same filename!
extracampine
Post by extracampine »
See attached screenshot; when converting a multi-page PDF to PNG, the XnConvert status window shows that each page of the PDF is loaded and saved individually - but the filename of each PNG is the same, so that every time a new page of the PDF is saved, it over-writes the previous one!!
https://imgur.com/a/2btLJuI
Re: Each page of converted PDF saved with same filename!
which settings do you use?
