Assume I am currently in Gallery view mode. All images from the current directory are shown with their corresponding thumbnails.
Now I resized the main window to an appropriate size.
When I double click now on one of the image thumbnails the corresponding full image shown in single image view mode.
Auto Image Size="Fit window to image"
When I press now the ESC key then XnView returns to the gallery view and restores the previously remembered Gallery window size.
All that is fine.
Now sometimes I double click onto the single image (instead of pressing the ESC key).
And yes XnView returns here to gallery view as well. BUT it restores here NOT always the previously remembered window size but a much smaller size.
I couldn't figure out when XnView restores the gallery window to the original and when not.
I guess it has something to do if I drag&drop an image to another directory before. or delete an image just before.
But I want ALWAYS to restore the original gallery windows size (and position). ALWAYS (!). Even when I double click on an image in single view mode.
The gallery window size should ALWAYS be the same
If there is no setting then its a bug.
Can someone verify this?
Thank you
Tobias
ALWAYS (!) remember gallery window size when double click on single image
Re: ALWAYS (!) remember gallery window size when double click on single image
Options>Interface>Use different size is checked?
ok, will be fixed
