JPEGTRANS plus RESIZE plus IPTC
Peter2
Post by Peter2 »
I stumbled into my semi-finished project from this spring where I posted already some questions
I want to
- always convert (mostly) JPG to JPG (basically solved)
- always keep the quality (unsolved because of bug in software)
- always rotate to exif-orientation (semi-unsolved due to unclear behaviour of jpegtrans which can only be used as single parameter)
- always write IPTC-data to JPG (depending from jpegtrans)
- optionally "resize" to 2000px
- optionally add text to the image
So I want to ask for the best usage and order of the parameters:
- jpegtrans always alone and as first command?
- then IPTC and resize as second, independent call of Nconvert?
- then optional text?
- what to do with quality?
Thanks for advice!
Peter
Peter2
Re: JPEGTRANS plus RESIZE plus IPTC
Post by Peter2 »
Nobody knows?
Have a fine weekend!
Peter2 wrote: Mon Jul 19, 2021 5:04 pm - jpegtrans always alone and as first command?
First lossless command:
- jpegtrans
- IPTC
And:
- resize, text
Peter2
Post by Peter2 »
To sum up - I need three independent, following calls of nconvert.exe?
Peter2 wrote: Wed Aug 04, 2021 10:16 am To sum up - I need three independent, following calls of nconvert.exe?
yes
