b1: Fullscreen and Taskbar Isn't Hidden
ckit
Post by ckit »
Sometimes when going to Fullscreen with some pictures the Taskbar is visible and has not disappeared like it should.
XnView 1.82 <x>
Xyzzy
Post by Xyzzy »
I remember this problem from 1.74. It disappeared in 1.80.
X.
Re: b1: Fullscreen and Taskbar Isn't Hidden
ckit wrote:Sometimes when going to Fullscreen with some pictures the Taskbar is visible and has not disappeared like it should.
I confirm
ckit
Post by ckit »
This bug is still present in Beta 2 but it appears less than before.
ckit wrote:This bug is still present in Beta 2 but it appears less than before.
Do you have a way to reproduce it every time?
ckit
Post by ckit »
Currently, no but I am looking for clues.
Update:
Using "Always on Top" in the Startup options seems to fix it.
ckit
Post by ckit »
Ok, I now believe this bug is connected to the new "Hide scrollbar" feature in Fullscreen options.
I'll provide a screenshot as to why I think this.
I had the "Hide scrollbar" feature unchecked and now I have it checked as I dig deeper into the taskbar bug.
ckit wrote:Ok, I now believe this bug is connected to the new "Hide scrollbar" feature in Fullscreen options.
With or without 'Fullscreen/hide scrollbar', i can't reproduce it all the time
Xyzzy
Post by Xyzzy »
b2
deleted .ini
Get this picture:
http://img308.imageshack.us/my.php?imag ... aga7zr.png
Run XnView. Change Options>General.Switching modes>double click to Browser<>Fullscreen.
Double click image in browser.
Task bar is still visible on fullscreen display.
X.
ckit
Post by ckit »
Hmmm, interesting everytime I found the bug I was using F11 to go to Fullscreen.
So far, I can only reproduce this bug 50% of the time - really annoying too.
I've also updated to ATI 5.12 video drivers and that didn't help and before someone says ATI 5.13 is out - I already know.
Xyzzy wrote:b2
deleted .ini
Get this picture:
No :-( Tried on windows 2K
Post by Guest »
xnview wrote:No :-( Tried on windows 2K
Hmm, here WindowsXP, some older ATI Catalyst drivers (5.7 or so).
I tried also on i845 integrated graphics and there is no problem.
It seems the problem is ATI related, so maybe let's postpone it until you have an occassion to check on ATI chipset?
X.
Xyzzy
Post by Xyzzy »
That was me, Xyzzy!
marsh
Post by marsh »
Probably not helpful: I cannot recreate it every time, but I can make it occur more often:
-800x600 screen Using browser+F11
A. 640x480 69K jpg High Quality settings taskbar image appears much more frequently.
B. 1600x1200 776K jpg HQ settings. taskbar never appears?
C. 1600x1200 776K jpg LQ settings. taskbar sometimes starts to appear and then it looks like it is shoved out of the way.
Don't think that problem is related to ATI, ???
