JPEG-XL
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderators: XnTriq, helmut, xnview, Dreamer
rotiya
JPEG-XL
Post by rotiya »
Is it possible to export (convert) images to JPEG-XL already?
in the regular export window, all I see is Jpeg-XR which is of course different.
Re: JPEG-XL
yes with 'save as'
rotiya
Re: JPEG-XL
Post by rotiya »
xnview wrote: Fri Jul 02, 2021 7:12 am yes with 'save as'
I see, thank you for the answer.
Is there a reason why it's missing from the export option?
Also, will it get added to the XnView Shell extension so we can easily batch convert images to JXL?
Using "save as" JXL, there are no options available, so I have no idea what settings are used, lossless, or lossy (or how lossy).
Re: JPEG-XL
Currently lossless is used, next release will fix that
Hacker
Re: JPEG-XL
Post by Hacker »
Hi Pierre,
xnview wrote: Mon Jul 05, 2021 12:03 pm Currently lossless is used, next release will fix that
The link you posted leads back to this topic.
Roman
Re: JPEG-XL
right, link fixed
Re: JPEG-XL
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
r2sd
Re: JPEG-XL
Post by r2sd »
I am unable to view JPEG-XL files on Mac, is this expected?
Version:
XnView MP MacOSX
Version 0.99.6 64bits (Dec 10 2021)
Re: JPEG-XL
r2sd wrote: Thu Dec 23, 2021 3:33 pm I am unable to view JPEG-XL files on Mac, is this expected?
Currently not yet JPEGXL support on linux/macos
acedogblast
Re: JPEG-XL
Post by acedogblast »
xnview wrote: Fri Dec 24, 2021 6:45 am
When can JPEG-XL be supported on the Linux client?
magick
Re: JPEG-XL
Post by magick »
Is there a plan to support it on MacOS (and Linux) at all??
what it depends on?
Re: JPEG-XL
magick wrote: Wed Apr 05, 2023 11:26 am Is there a plan to support it on MacOS (and Linux) at all??
what it depends on?
JPEGXL is supported on MacOS
jrs62
Re: JPEG-XL
Post by jrs62 »
Hello! Some morons are messing around with a JPEG XL article on the English Wikipedia about XnView MP Linux.
This isn't the first time they've done this kind of thing. Nobody of you should care about them.
Bye!
PS. Fuck you Jimmy Wales.
jrs62
Re: JPEG-XL
Post by jrs62 »
Everything is also removed. Wikinazis also harass, slander, stalk, opress and censor users. It only takes them a few minutes to do this. The morons can't even speak English. They speak random horseshit that looks like English.
It's the most pathetic piece of shit, stinky and loud shithole on the Internet.
Fuck Jimmy Wales in every single way.
magick
Re: JPEG-XL
Post by magick »
xnview wrote: Fri Apr 07, 2023 7:27 am
what it depends on?
Actually it is not.
I am having latest version (1.6.4 as of today) and it doesn't recognize it.
Am I missing something? any optional libs or so?
