better distinguish between new and ols skin
klumy
Post by klumy »
XNView should have an option to display that a skin is too old for this version (means, that it doesn not support all available buttons)
XNView 1.91.5
Windows XP SP3
Re: better distinguish between new and ols skin
klumy wrote:XNView should have an option to display that a skin is too old for this version (means, that it doesn not support all available buttons)
Perhaps i must remove from default package old skin??
klumy
Post by klumy »
this would also be an solution :)
XNView 1.91.5
Windows XP SP3
It's no good that toolbar buttons are missing if a skin doesn't provide the bitmap for it. But removing skins would be an overkill and the wrong action, I think. We should rather go ahead and try to complete all thumbnails asap. Sure enough designing toolbar buttons is a designer task, not forum members' task.
Currently i haven't received missing button from original designer :-(
