Draw: Undo/Redo keyboard shortcuts don't work
Anibina
Post by Anibina »
System
XnView MP Windows, Version 0.98.4 64bits (May 28 2021)
Windows Version 21H1
Reproduction steps
Open an image
Open the draw window: Image > Draw
Select the "Draw a rectangle" tool
Draw a rectangle
Press: Ctrl z
Expected
The rectangle should be removed.
Observed
Nothing happens.
It doesn't help to left click outside the rectangle to commit the shape,
so that it isn't editable anymore.
The Undo and Redo buttons work.
The Redo keyboard shortcut: Ctrl y
doesn't work either after having pressed the Undo button and the Redo button becoming enabled.
Re: Draw: Undo/Redo keyboard shortcuts don't work
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
Anibina
Post by Anibina »
Undo with Ctrl z and Redo with Ctrl y works in 0.99.0. Thank you.
