Can't convert PNG to WebP
Re: Can't convert to WebP
dedbombom wrote: Mon Jan 02, 2023 12:09 pm
xnview wrote: Mon Jan 02, 2023 9:27 am I don't understand, by default, if you convert png->webP, the alpha is not lost
x-patreon.zip
Sry, something wrong with attached file. It wasn't 256 color, here is correct one https://workupload.com/file/N2nWPR9C3sm
Ok, will be fixed
dedbombom
Post by dedbombom »
xnview wrote: Tue Jan 03, 2023 8:36 am
x-patreon.zip
Ok, will be fixed
Thanks, would be nice especially if it would be handled by nconvert by default without additional commands.
dedbombom
Re: Can't convert PNG to WebP
Post by dedbombom »
Main nconvert page says that now it contains v7.135 but in fact its still older v7.121 (at least for Windows, both x64 and x86).
dedbombom wrote: Tue Jan 17, 2023 8:33 am Main nconvert page says that now it contains v7.135 but in fact its still older v7.121 (at least for Windows, both x64 and x86).
an error, the new version is not yet available
dedbombom
Post by dedbombom »
xnview wrote: Tue Jan 17, 2023 11:12 am
But how to get actual info about upcoming update then coz it's not like this page viewtopic.php?f=57&t=42650 updates frequently?
dedbombom
Post by dedbombom »
So in new version now it works with "-merge_alpha -truecolors" flags but would be better if handled by default without any additional commands. But thx anyway...
dedbombom
Post by dedbombom »
So far problem still exist: for example if nconvert spots "fake" png that is webp for real then it's removes transparency again if used "-merge_alpha -truecolors". But "-32bits" works fine - I think it should be suggested for me instead others.
dedbombom wrote: Wed Feb 01, 2023 10:44 am So far problem still exist: for example if nconvert spots "fake" png that is webp for real then it's removes transparency again if used "-merge_alpha -truecolors". But "-32bits" works fine - I think it should be suggested for me instead others.
could you post image file with problem?
dedbombom
Post by dedbombom »
xnview wrote: Thu Feb 02, 2023 7:41 am
Example image https://workupload.com/file/rRzT87t2aNa and command "nconvert -merge_alpha -truecolors -out webp -o oner.webp oner.png" but maybe it's not bug and such behaviour (removing transparency) is intended for webp files with those commands. Anyway I found a command "-32bits" that works fine in my case when nconvert couldn't convert (at least without transparency loss) png images to webp made with 256 colors so for me problem is solved.
