[0.98.3] Category Sets input field does not clear
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
jadO
Post by jadO »
Maybe it is bug or a feature suggestion:
The new input field for category sets does not clear when selecting another file. I think it should clear.
1. Go to Category Sets
2. Select a file
3. Assign category with new input field
4. Switch to another file
Result is that the new input field keeps showing the category of the previous file.
Suggestion: I think the input field should become empty: 1. After category has been assigned, 2. When selecting a new file.
Re: [0.98.3] Category Sets input field does not clear
This problem is supposed to be fixed in XnView MP 0.98.4. Please check and confirm the bug fix here.
