Please, don't post bugs or request in this topic!
You can download XnView MP 0.98.3 here:
Windows x32 ZIP version SHA256: 166D1D9FFB3A4060FFFDEE2EFABD89B78D9EFF9E0F3482F15BCB54DDA26B27F3
Windows x32 SETUP version SHA256: AF06A04140645141C618242A3D871CD071D7BE23B9FB4EB28ACE81BC9CC436CC
Windows x64 ZIP version SHA256: EEC3536119D19BC9F8893E21BDEC0AEE13C3982713906061C2C0496AE92CA5FE
Windows x64 SETUP version SHA256: 6784C15B6B400C6181D2A1D989E83234D1286469217BD71EBB49A7CED4A803EF
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: 2102A1A65219EC2DE2CE63C0F8248B4C32CDA0304E8ABBAACD5052DEAEA62583
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version SHA256: 43D508587227CD072024DEDD911ED1466C7AB67ABE8D7032D50290CE60147935
Linux x64 DEB version SHA256: F0DF2CF27DCD154846FB5B30057F9C737F7DD917B11F30ACE0B352503FD54A5C
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.98.3:
2051: [New] EXIF>LensModel/LensMake added
2046: [New] Import&Sort: Sidecar option to write keywords - viewtopic.php?t=41795
2043: [New] Zoom out filter (Bicubic, Spline, Lanczos)
2042: [New] Alphabetically sort - viewtopic.php?t=41777
2037: [New] Timestamp: option to force update - viewtopic.php?t=41746
2022: [New] Browser: Statusbar customization - viewtopic.php?t=41682
2019: [New] Category Sets - viewtopic.php?t=41557
2016: [New] Export Catalog enhancements - viewtopic.php?t=41693
2009: [New] 'Edit XMP' in context menu - viewtopic.php?t=41653
2006: [New] ResizePreset.txt in AppData - viewtopic.php?t=41610
2002: [New] Quick Search: catalog keywords - viewtopic.php?t=41617
2054: [Bug] TIFF Black levels EXIF field - viewtopic.php?t=41846
2053: [Bug] EXIF date 1900 not correctly sorted - viewtopic.php?t=41838
2052: [Bug] No warning for a rotation on HEIC - viewtopic.php?t=41774
2050: [Bug] Crash on .ani
2049: [Bug] On HiDPI screen, small images are with 99% zoom - viewtopic.php?t=41797
2048: [Bug] HiDPI & bicubic-lanczos filter - viewtopic.php?t=41797
2047: [Bug] HiDPI & b&w image - viewtopic.php?t=40984
2045: [Bug] JPEG XR - viewtopic.php?t=41792
2044: [Bug] Edit GPS: Copy/Paste problem - viewtopic.php?f=83&t=39706
2041: [Bug] Crash when moving/selecting category
2040: [Bug] Detail view & rating/label with 125% font scaling - viewtopic.php?t=41752
2039: [Bug] CR2 orientation problem
2038: [Bug] descript.ion is missing when moving folder - viewtopic.php?t=41743
2036: [Bug] Ghostscript 9.54 - viewtopic.php?f=93&t=41756
2035: [Bug] Edit IPTC: On MacOS Alt+left/right arrow to change file
2034: [Bug] 'show people region' should be persistent - viewtopic.php?t=41742
2033: [Bug] Image always loaded even if preview is off - viewtopic.php?t=41719
2032: [Bug] Annoying tooltips on category pane - viewtopic.php?t=41730
2031: [Bug] Region name - viewtopic.php?t=41740
2030: [Bug] Preview pane: auto image size not saved - viewtopic.php?t=41715
2029: [Bug] Canvas resize - restore default - viewtopic.php?t=41707
2028: [Bug] Thumbnail loading crash sometimes
2027: [Bug] GEM vulnerability - Thanks to Michael Heinzl
2026: [Bug] Print size rounded value - viewtopic.php?t=41504
2025: [Bug] 'Use alpha channel' in browser's preview
2024: [Bug] SPACE to play/pause video in browser - viewtopic.php?t=34514
2023: [Bug] Slideshow: delay limit - viewtopic.php?t=41096
2021: [Bug] Default properties dialog in edit mode - viewtopic.php?t=41704
2020: [Bug] IPTC dialog in edit mode should not change state of image is 'Write' - viewtopic.php?t=39280
2018: [Bug] Incorrect value for {DstWidth} - viewtopic.php?t=41692
2017: [Bug] 'Save' confirmation dialog - viewtopic.php?t=41683
2015: [Bug] PNG & Large iTxt - viewtopic.php?t=41677
2014: [Bug] Hidden folder disappear - viewtopic.php?t=39325
2013: [Bug] Category Sets re-assignment via History not possible - viewtopic.php?t=41689
2012: [Bug] Comment: hotkey for 'write all' - viewtopic.php?t=41687
2011: [Bug] Edit XMP: CreateDate should use Exif:DateTaken - viewtopic.php?t=41654
2010: [Bug] Edit XMP: Field remove - viewtopic.php?t=41656
2008: [Bug] Crash when AVIF renamed as HEIC - viewtopic.php?t=41665
2007: [Bug] 'Only one instance' & foreground window on Windows- viewtopic.php?t=41551
2005: [Bug] ORI extension - viewtopic.php?t=168437
2004: [Bug] Icon on lossless totate - viewtopic.php?t=41660
2003: [Bug] Import&Sort: Filename not renamed - viewtopic.php?t=41648
2001: [Bug] Custom order and viewing - viewtopic.php?t=38663
2000: [Bug] Catalog: Check folders doesn't remove orphaned files - viewtopic.php?t=41603
1999: [Bug] Banner & RGBA - viewtopic.php?t=41621
1998: [Bug] Wallpaper & windows font scaling - viewtopic.php?t=36967
1997: [Bug] Clip format- viewtopic.php?t=38583
Changelog 0.98.2:
1996: [New] New tags/categories system
1994: [New] Paint: arrow keys to move object
1993: [New] Edit mode: 'Save as' on close confirmation dialog
1990: [New] RIOT support (edit mode)
1985: [New] Watermark feature in view mode
1984: [New] Capture: copy to clipboard option - viewtopic.php?t=41495
1981: [New] Text feature in edit mode
1976: [New] libJPEGXL v0.3 - break compatilility with v0.1
1995: [Bug] XRecoil
1992: [Bug] Transfer: missing fields - viewtopic.php?t=41544
1991: [Bug] XMP:subject
1989: [Bug] Save JPEG with extended XMP - viewtopic.php?t=41510
1988: [Bug] & in tab title - viewtopic.php?t=41241
1987: [Bug] Image scaled on HiDPI screen - viewtopic.php?t=40984
1986: [Bug] 'Estimated quality' not always displayed - viewtopic.php?t=33795
1983: [Bug] Batch clean metadata - viewtopic.php?t=41367
1982: [Bug] MacOS: column size - viewtopic.php?t=41491
1977: [Bug] Image in low resolution sometimes with Bicubic/Spline/Lanczos filter - viewtopic.php?t=41501
1980: [Bug] Extra '.' to folder copied
1979: [Bug] Sometimes crash in folder pane
1978: [Bug] Strange image display when zoom < 100, different dpi zoom, bilinear
1975: [Bug] Search: between 2 same dates - viewtopic.php?t=41476
1974: [Bug] Batch Convert: nconvert & rotate - viewtopic.php?t=41471
1973: [Bug] Setting View>Show rating - viewtopic.php?t=41473
1972: [Bug] EXIF Exposure time
1971: [Bug] Film simulation removes metadata - viewtopic.php?t=41460
1970: [Bug] Color depth: 'Apply to image' not canceled - viewtopic.php?t=41454
1969: [Bug] Similar: Wrong similarity after sort - viewtopic.php?t=41437
1968: [Bug] Change color depth & 32bits picture - viewtopic.php?t=41431
1967: [Bug] GIF bad image size - viewtopic.php?t=41422
1966: [Bug] Strip: Spacing & row number - viewtopic.php?t=41439
Changelog 0.98.1:
1958: [New] Zoom-in filter (Bicubic, Spline, Lanczos)
1952: [New] Batch convert: 'fill width' option for text background
1888: [New] mm in print size - http://newsgroup.xnview.com/viewtopic.php?t=41115
1895: [New] IPTC: merge option when importing template - http://newsgroup.xnview.com/viewtopic.php?t=37535
1965: [Bug] Windows: scaling problem - http://newsgroup.xnview.com/viewtopic.php?t=40984
1964: [Bug] Print & margins - http://newsgroup.xnview.com/viewtopic.php?t=41272
1963: [Bug] TIFF & EXIF setting - http://newsgroup.xnview.com/viewtopic.php?t=41405
1962: [Bug] Batch convert: Keep IPTC/XMP/EXIF/ICC - http://newsgroup.xnview.com/viewtopic.php?t=41405
1961: [Bug] Collage: spacing not used - http://newsgroup.xnview.com/viewtopic.php?t=41402
1960: [Bug] WebP animation crash - http://newsgroup.xnview.com/viewtopic.php?t=40157
1959: [Bug] MacOS-Linux: Slow starting with a lot of subfolders - http://newsgroup.xnview.com/viewtopic.php?t=41372
1957: [Bug] Convert: Deleting original files on Linux-MacOS don't work - http://newsgroup.xnview.com/viewtopic.php?t=41383
1956: [Bug] Old version of ghostscript not recognized - http://newsgroup.xnview.com/viewtopic.php?t=40907
1955: [Bug] Strip: Image orientation problem
1954: [Bug] Search similar: Tolerance problem - http://newsgroup.xnview.com/viewtopic.php?t=41324
1953: [Bug] Unexpected zoom behavior of selection function - http://newsgroup.xnview.com/viewtopic.php?t=41319
1951: [Bug] Paste outside - http://newsgroup.xnview.com/viewtopic.php?t=41348
1950: [Bug] Saved selection not kept between session
1949: [Bug] IPTC/XMP: Load template - viewtopic.php?t=41344
1948: [Bug] Info icon display problem on hDPI
1947: [Bug] Slideshow: Problem when saving settings
1946: [Bug] Slideshow: Text position not saved in .sld - http://newsgroup.xnview.com/viewtopic.php?t=41051
1945: [Bug] Tag not working - http://newsgroup.xnview.com/viewtopic.php?t=41321
1944: [Bug] MWG not correctly imported - http://newsgroup.xnview.com/viewtopic.php?t=39741
1896: [Bug] GIF frame by frame - http://newsgroup.xnview.com/viewtopic.php?t=40023
1943: [Bug] Create banner without files
1942: [Bug] Batch converter with Animated GIF results in crash - http://newsgroup.xnview.com/viewtopic.php?t=41314
1941: [Bug] Video thumbnail crash (MP4)
1940: [Bug] 'Random file' always enabled - http://newsgroup.xnview.com/viewtopic.php?t=41310
1880: [Bug] GPS>Satellite crash on Windows
1939: [Bug] Duplicate file dialog - http://newsgroup.xnview.com/viewtopic.php?t=41307
1938: [Bug] Rating overwrites categories in .xmp companion file - http://newsgroup.xnview.com/viewtopic.php?t=41278
1937: [Bug] No export to .xmp companion file / empty .xmp - http://newsgroup.xnview.com/viewtopic.php?t=41277
1936: [Bug] 'Enhance colors' crash on big image
1935: [Bug] Print scanned document (dpi) - http://newsgroup.xnview.com/viewtopic.php?t=41273
1934: [Bug] Crop size in portrait - http://newsgroup.xnview.com/viewtopic.php?t=41274
1933: [Bug] Sub-sampling info for 4:4:0 JPEG is wrong - http://newsgroup.xnview.com/viewtopic.php?t=41245
1932: [Bug] & in tab title - http://newsgroup.xnview.com/viewtopic.php?t=41241
Changelog 0.98.0:
1916: [New] Special label to show rating & color label - http://newsgroup.xnview.com/viewtopic.php?t=37766
1928: [New] 'Use original format' setting - http://newsgroup.xnview.com/viewtopic.php?t=41008
1926: [New] 'Show sbufolder' & update - http://newsgroup.xnview.com/viewtopic.php?t=35074
1925: [New] Capture: play sound setting
1923: [New] Icon when sidecar is used - http://newsgroup.xnview.com/viewtopic.php?t=38436
1922: [New] Categories filter (root) expanded state saved - http://newsgroup.xnview.com/viewtopic.php?t=37936
1920: [New] Menu item to toggle high zoom quality - http://newsgroup.xnview.com/viewtopic.php?t=37347
1913: [New] 'Save' as copy setting - http://newsgroup.xnview.com/viewtopic.php?t=40745
1912: [New] Left/Right button => Prev/Next file - http://newsgroup.xnview.com/viewtopic.php?t=40018
1910: [New] EXIF codec - http://newsgroup.xnview.com/viewtopic.php?t=41186
1909: [New] Batch convert: Drop shadow - direction - http://newsgroup.xnview.com/viewtopic.php?t=39888
1908: [New] Crop: Center - http://newsgroup.xnview.com/viewtopic.php?t=39395
1907: [New] Import: Counter per folder - http://newsgroup.xnview.com/viewtopic.php?t=39752
1905: [New] libjpeg-turbo 2.0.6
1904: [New] More template for duplicate file - http://newsgroup.xnview.com/viewtopic.php?t=40875
1903: [New] 'Save all' - http://newsgroup.xnview.com/viewtopic.php?t=41062
1902: [New] Video loop - http://newsgroup.xnview.com/viewtopic.php?t=40014
1899: [New] 'Select all files' - http://newsgroup.xnview.com/viewtopic.php?t=40810
1898: [New] Info pane: Empty tabs option - http://newsgroup.xnview.com/viewtopic.php?t=38204
1897: [New] Settings>Catalog - Check folders - http://newsgroup.xnview.com/viewtopic.php?t=41109
1894: [New] Search: for non categorized - http://newsgroup.xnview.com/viewtopic.php?t=39815
1893: [New] Copy/Move dialog: clear - http://newsgroup.xnview.com/viewtopic.php?t=40074
1891: [New] Scan headers setting - http://newsgroup.xnview.com/viewtopic.php?t=39113
1889: [New] WebP Animation - http://newsgroup.xnview.com/viewtopic.php?t=40549
1887: [New] Slideshow: GIF playing - http://newsgroup.xnview.com/viewtopic.php?t=40970
1886: [New] Slideshow info position - http://newsgroup.xnview.com/viewtopic.php?t=41051
1881: [New] Batch convert: Mono mixer - http://newsgroup.xnview.com/viewtopic.php?t=39578
1877: [New] Small toolbar layout - http://newsgroup.xnview.com/viewtopic.php?t=41077
1876: [New] Display MWG-Regions and names on image - http://newsgroup.xnview.com/viewtopic.php?t=39741
1874: [New] Batch rename: reorder more than 1 file
1873: [New] Batch rename: Confirmation to delete templates - http://newsgroup.xnview.com/viewtopic.php?t=41033
1872: [New] Color model & Compression as placeholder - http://newsgroup.xnview.com/viewtopic.php?t=41026
1868: [New] Random file in edit mode - http://newsgroup.xnview.com/viewtopic.php?t=40337
1867: [New] XMP dialog - http://newsgroup.xnview.com/viewtopic.php?t=40080
1931: [Bug] Sidecar not deleted when viewing category - viewtopic.php?t=41204
1930: [Bug] Batch convert should not change global write format settings - http://newsgroup.xnview.com/viewtopic.php?t=41201
1929: [Bug] Set category create a sidecar without original XMP values
1927: [Bug] Ctrl+Right click in detail view - http://newsgroup.xnview.com/viewtopic.php?t=36951
1924: [Bug] ESC to quit - http://newsgroup.xnview.com/viewtopic.php?t=41135
1921: [Bug] Settings not propagated to Fullscreen's browser - http://newsgroup.xnview.com/viewtopic.php?t=37710
1919: [Bug] Favorites must not shown files
1918: [Bug] MacOS-Linux: File sorting error - http://newsgroup.xnview.com/viewtopic.php?t=40046
1917: [Bug] 16bits PNG + color profile - http://newsgroup.xnview.com/viewtopic.php?t=41196
1915: [Bug] Extension shown for folder - http://newsgroup.xnview.com/viewtopic.php?t=41192
1914: [Bug] Movie & playbar - http://newsgroup.xnview.com/viewtopic.php?t=41195
1911: [Bug] Transfer: XPTitle label - http://newsgroup.xnview.com/viewtopic.php?t=41183
1906: [Bug] Import: rename video file - http://newsgroup.xnview.com/viewtopic.php?t=39836
1901: [Bug] Drop files outside Xn on subfolder - http://newsgroup.xnview.com/viewtopic.php?t=40334
1900: [Bug] Change timestamp on video file - http://newsgroup.xnview.com/viewtopic.php?t=40150
1892: [Bug] Copy/Mode Dialog: show hidden setting - http://newsgroup.xnview.com/viewtopic.php?t=40422
1890: [Bug] Batch convert: AVIF params not saved - http://newsgroup.xnview.com/viewtopic.php?t=41150
1885: [Bug] AVIF settings - http://newsgroup.xnview.com/viewtopic.php?t=41134
1884: [Bug] Batch convert: Normalize Ex
1883: [Bug] Export: edit colormap crashs
1882: [Bug] Rating/color not imported from Classic - http://newsgroup.xnview.com/viewtopic.php?t=41108
1879: [Bug] Favorite: Folder can't be deleted - http://newsgroup.xnview.com/viewtopic.php?t=39851
1878: [Bug] Setting for showing rating - http://newsgroup.xnview.com/viewtopic.php?t=40908
1875: [Bug] Edit comment doesn't update the view info correctly
1871: [Bug] Batch convert: change color depth & alpha - http://newsgroup.xnview.com/viewtopic.php?t=40680
1870: [Bug] Custom sort - http://newsgroup.xnview.com/viewtopic.php?t=41084
1869: [Bug] Crop: selection size - http://newsgroup.xnview.com/viewtopic.php?t=41047
1866: [Bug] Batch convert: Resize slow - http://newsgroup.xnview.com/viewtopic.php?t=41044
1865: [Bug] Batch convert: \# => \\# in filename
Changelog 0.97.1:
1863: [New] Capture rectangle on second screen - http://newsgroup.xnview.com/viewtopic.php?t=40830
1862: [New] Capture on second screen - http://newsgroup.xnview.com/viewtopic.php?t=37603
1854: [New] '#' can be escaped by '\#' - http://newsgroup.xnview.com/viewtopic.php?t=40917
1864: [Bug] HEIF leaks on MacOS
1861: [Bug] Pan tool - http://newsgroup.xnview.com/viewtopic.php?t=40918
1860: [Bug] Thumbnail border size & alpha - http://newsgroup.xnview.com/viewtopic.php?t=40868
1859: [Bug] Search: Pathname & catalog - http://newsgroup.xnview.com/viewtopic.php?t=40910
1858: [Bug] 'Select All' & Focus - http://newsgroup.xnview.com/viewtopic.php?t=40993
1857: [Bug] Catalog wrong files count - http://newsgroup.xnview.com/viewtopic.php?t=40947
1856: [Bug] Batch convert: crash Resize by Mpixels
1855: [Bug] Batch rename & Del don't work - http://newsgroup.xnview.com/viewtopic.php?t=40995
1853: [Bug] nbsp in tooltips
1852: [Bug] Ghostscript 9.53.x
1851: [Bug] Set/update category crash
Changelog 0.97.0:
1844: [New] Qt 5.15.0
1850: [New] IPTC: custom filename for template
1849: [New] MacOS: Internal video codec
1848: [New] Start in browser mode - viewtopic.php?f=82&t=40843
1847: [Bug] Offset repeat - viewtopic.php?f=62&t=40856
1846: [Bug] BLP - viewtopic.php?f=82&t=40862
1845: [New] JPEG XL
1842: [New] HEIF
1840: [Bug] 'select all' & focus - viewtopic.php?f=62&t=40834
1839: [New] LIBPNG 1.6.37
1838: [New] VS 2019 build
1837: [New] SQLite 3.33.0
1836: [New] XMP Toolkit
1835: [New] OpenJPEG 2000
1834: [New] LCMS 2.11
XnView MP 0.98.3
XnView MP 0.98.3
