Exif Data Missing (Black Levels)
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
benjimeltzer
Post by benjimeltzer »
We would like to use xnconvert/xnresize to decrease the size of some multispectral images but we have run into some trouble with certain exif tags.
In particular the "Black levels" tag is missing from the output.
This tag is needed to calibrate brightness of multispectral data from the Micasense camera. Do you know why this could be?
Any help would be appreciated.
Sample files before and after conversion can be found here: https://drive.google.com/drive/folders/ ... sp=sharing.
Re: Exif Data Missing (Black Levels)
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
