XnView 2.50
XnView 2.50
Dear user,
XnView 2.50 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 900B967C77DFE39452CCDF53C404E5EC8DD414256BE63B0CB497CC1A034F7C53
XnView-win.zip: 97F26CF05604972F91C6BC218F57C0F044DB67144BCEE7FC5D09BCD44F4DD083
XnView-win-full.exe: 8591235824E801F66BDAA7D7AE55B7CE613D1DD4553B5F48A7063AEF4E1A5642
XnView-win-full.zip: A845329AAEBACE62E51AB1CDC60E81009CA172046F7D80522D0088514A420F2B
XnView-win-small.exe: A00024FCF6444647747118AF4E0A5EF2346FF0EBD5DDCD3C316C720DA93259D2
XnView-win-small.zip: 2EB26DD85052A782531178800839251E3C7C5C3D72CA6023FDCF3841A7763A35
____ 2.50 Changelog
* APNG crash - viewtopic.php?f=36&t=41803
* JPEGXR RGB10
* CR2 orientation problem
* Ghostscript 9.54
* Recoil
* GEM vulnerability - Thanks to Michael Heinzl
* NConvert: -use_org_quality problem
* jpegtrans not written for NConvert - viewtopic.php?f=36&t=41826
* NConvert: -text_font name percent - viewtopic.php?f=57&t=41811
* NConvert: -canvas shortest/longest - viewtopic.php?f=57&t=41812
____ 2.49.5 Changelog
* Ghostscript detection
* TIFF - viewtopic.php?f=35&t=41136
* HEIF plugin - viewtopic.php?f=36&t=41104
* Old versions of ghostscript not recognized
* NConvert: -use_org_quality - viewtopic.php?f=57&t=41397
* NConvert: multiple text lines - viewtopic.php?f=57&t=41358
____ 2.49.4 Changelog
* Ghostscript 9.53.x
* GPS & file date - viewtopic.php?f=56&t=40971
* TIFF Security vulnerability (Thanks to Michael Heinzl)
* NConvert: -levels2 - viewtopic.php?f=57&t=40490
* NConvert: -resize supports cm/mm/inches
* NConvert: -autodeskew fixed
* NConvert: -noholder to disable %$ chars - viewtopic.php?f=57&t=40820
____ 2.49.3 Changelog
* Convert 16 to 256 colors - viewtopic.php?f=36&t=39421
* Disable ESC to close tabs - viewtopic.php?f=35&t=17078
[General] EscToCloseView=0
* Select file from search results & switching mode - viewtopic.php?f=34&t=40063
* Title empty when recurse - viewtopic.php?f=36&t=39979
* Resize - viewtopic.php?f=35&t=40248
* Slideshow: Order of files - viewtopic.php?f=56&t=40087
* Fortis Mag fix
* NConvert: -wmsize watermark percent size - viewtopic.php?f=57&t=38754
* NConvert: canvas size in inches/cm/mm - viewtopic.php?f=57&t=39361
* NConvert: replace_color - viewtopic.php?f=57&t=39769
* NConvert: -temperature added
____ 2.49.2 Changelog
* Problem with Ghostscript 9.50
* PDF font problem - viewtopic.php?f=36&t=39662
* CR3 - viewtopic.php?f=35&t=39478
* .sld must use 'Recurse' setting - viewtopic.php?f=35&t=39330
* GIF loop - viewtopic.php?f=36&t=31689
* PAM CMYK
____ 2.49.1 Changelog
* TIFF 16bits greyscale
____ 2.49 Changelog
* SQLite 3.29.0
* NConvert: greater_than/less_than condition - viewtopic.php?f=57&t=39147
* PSD: Error when writing metadata - viewtopic.php?f=57&t=39137
* Export - Problem with RGBA - viewtopic.php?f=36&t=39044
* Capture - viewtopic.php?f=36&t=38934
* Left/Right F11 to open fullscreen on Left/Right monitor
* Create multi file & folder with '.' - viewtopic.php?f=36&t=39008
* # to comment line in .sld file
* Multipage create: Check if output filename exists
* Slideshow crash when using animated GIF - viewtopic.php?f=36&t=38902
* XIM format import added
* Change timestamp must not use 12h format - viewtopic.php?f=36&t=38702
* GIF not played correctly in Slideshow - viewtopic.php?f=34&t=38303
* CVE - https://github.com/apriorit/pentesting/ ... ugs/xnview
* NConvert: -unsharp
* NConvert: -exposure - viewtopic.php?f=57&t=39136
* NConvert: -colorize h l s
* NConvert: Remove EXIF orientation -exif_rotation - viewtopic.php?f=57&t=38648
* [Rename]/TemplateStart, position of number in template - viewtopic.php?f=34&t=38568
* CVE-2019-12151
* ShellEx: 'Convert...' & input fields
