HEIC Rotation - No Metadata Warning Message
OrangeEye
Post by OrangeEye »
When rotating HEIC images the warning message:
"Be careful, saving in this format will discard any existing metadata"
is not shown (as it is when you try to save as HEIC in any other way).
If one changes the rotation without ever having tried to save with xnview as an heic before
the meta data are lost (without any warning). Luckily I have a backup.
Hope this may help others.
Re: HEIC Rotation - No Metadata Warning Message
With XnView Classic?
OrangeEye
Post by OrangeEye »
Sorry, you are right. I am very new to XnView and wasn't aware that it could make a difference.
I installed the MP-version of xnview and I noticed the behavior with that version.
Can you move that thread or should I open another bug report in the other forum?
I think that you try to rotate in browser view?
OrangeEye
Post by OrangeEye »
Yes, a rotation in the browser view seems to save the file without the waring pop up message that the meta data will get lost.
This waring message appears only when you open the file (double click in browser view), rotate it from there and try to save afterwards.
This behavior is inconsistent and can't be as expected (since data loss appears when rotating HEIF from the browser view)
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
OrangeEye
Post by OrangeEye »
Thanks for the fix - I can confirm that the missing warning message has now been fixed.
