After scaling display to 125%, XnViewMP 0.98.2 doesn't show Labels/Ratings properly in Details View
cadu
Post by cadu »
As shown in this screen-recording (https://bit.ly/3sxwTWN), when I scale my display to 125%, XnViewMP 0.98.2 doesn't show Labels and Ratings properly in Details View.
I tried all HiDPI options under" properties>compatibility>change HI DPI settings", but no effect to restore a proper view of Labels and Ratings had effect.
Is it a bug?
If you need further information or more testing, just let me know.
Thanks,
Carlos
My display specs:
2560x1440 scaled 125%
Monitor Dell 27" U2719D
Graphics Intel UHD 630 + NVIDIA GTX 1050Ti 4GB
Other info
OS Windows 10 Pro 64bit
Notebook Dell XPS 9570
Core i7-8750H
Memory 16GB DDR4
Re: After scaling display to 125%, XnViewMP 0.98.2 doesn't show Labels/Ratings properly in Details View
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
