b1: Synchronize browser selection with current view
Locked
Lesmo16
Post by Lesmo16 »
'Synchronize browser selection with current view' not working with v.1.82 beta 1.
We had the same not long ago.
Everyone who believes in telekinesis, raise my hand!
Dreamer
Post by Dreamer »
Can't confirm, could you explain more please?
Re: [Bug 1.82b1] Synchronize browser selection with current
Lesmo16 wrote:'Synchronize browser selection with current view' not working with v.1.82 beta 1.
Works for me...
Dreamer
Re: b1: Synchronize browser selection with current view
Post by Dreamer »
Also with default settings? Try to rename .ini file and check...
Lesmo16
Post by Lesmo16 »
I was sure that I'd done it ... :?
Yes, it works with "virgin" settings! Sorry for confusing you with this thread.
Xyzzy
Post by Xyzzy »
Well, it is till a problem if the option was checked and was not working, as it not supposed to interact with other options I think.
X.
Dreamer
Post by Dreamer »
But there is a bug somewhere, maybe you could send your ini to Pierre...
Xyzzy
Post by Xyzzy »
Pierre, have you got the file?
This may be related to INI differences between 1.80 and 1.82.
X.
Xyzzy wrote:Pierre, have you got the file?
No i have not received the .ini
Xyzzy
Post by Xyzzy »
I think Close. No confirmation, no similar problem reported, and no feedback from poster for over a month.
X.
Locked
