xmp-dc:subject
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderators: XnTriq, helmut, xnview, Dreamer
herb
xmp-dc:subject
Post by herb »
Hello Pierre,
I am working on a Windows 10 system with version 0.98.2.
For dialog "Edit XMP..." I miss the tag xmp-dc:subject
This list-type tag is the XMP field for IPTC:keywords.
This would be very helpful, because the trend is to only use XMP in future instead of also IPTC-IIM
In this case dialog "Edit XMP..." must also have the "Edit IPTC..." (multi-selection) option: keep and add new value (subject)
Thanks in advance
herb
Re: xmp-dc:subject
If i add xmp-dc:subject, i need to add xmp-lr:hirearchicalSubject too, not easy to do like 'Edit IPTC'
herb
Re: xmp-dc:subject
Post by herb »
Hello Pierre,
yes, you are right.
Please do it.
Best regards
herb
Re: xmp-dc:subject
herb wrote: Sat Mar 20, 2021 9:06 pm yes, you are right.
Please do it.
yes but why? Having the categories tree in XMP edit?
herb
Re: xmp-dc:subject
Post by herb »
Hello Pierre,
In tools -> settings -> metadata -> IPTC & XMP you have 2 checkboxes:
- (1) Import XMP-subject or IPTC-keywords to catalogs categories
- (2) Export catalogs categories to XMP-subject and IPTC-keywords
In dialog EDIT IPTC... you can edit
- Keywords and
- Categories and SupplementaCategories.
All these fields can be edited independent on catalogs categories
In dialog EDIT XMP... you cannot edit
- subject (which is the corresponding XMP-field for IPTC-IIM keywords
- XMP-photoshop:category and XMP-photoshop:SupplementalCategories (which are the corresponding XMP-fields for IPTC-IIM fields
These fields are only written because of global setting (2)
And yes, to have also XMP-lightroom: HierarchicalSubject, is also a great feature.
Best regards
herb
Gwenael Q.
Re: xmp-dc:subject
Post by Gwenael Q. »
Hello Pierre,
This would be greatly appreciated.
XMP should not have poorer features than IPTC.
Thanks for listening
1.4.2
Re: xmp-dc:subject
please wait next release...
Re: xmp-dc:subject
