First startup after windows boot is extremely slow
Moderators: XnTriq, xnview
BK201
Re: First startup after windows boot is extremely slow
Post by BK201 »
xnview wrote: Mon Sep 20, 2021 9:59 am
BK201 wrote: Mon Sep 20, 2021 9:03 am Good job xnview, I finally got the answer of "how things could be worse"
Yes QT team has fixed the problem
Do you have problem of reading or understanding english sentences?
Oh my apologizes, i've seen
With the new version 0.99, the problem is fixed
not this one
Now it's slow start of EVERY run,
but it's really strange, all users having this issue have replied
0.99 is nearly instantly
From my tests, it starts in < 1sec
BK201
Post by BK201 »
I just got a brand new pc, I can still reproduce the problem, it's definitely not the problem of my hardware or softwares
I install xnview mp on a M.2 ssd which has a read speed of 4500MB/s, Windows 10 takes only 5 seconds to boot up while the first run of MP 0.99.1 takes 10 seconds pfff
My new spec
Windows 10 Home 64bit 21H1 (19043.1348)
11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz 2.59 GHz
GeForce RTX 3060 Ti 8GB GDRR6
HP M.2 SSD
BK201 wrote: Sat Nov 13, 2021 12:57 pm I just got a brand new pc, I can still reproduce the problem, it's definitely not the problem of my hardware or softwares
and second run?
BK201
Post by BK201 »
xnview wrote: Sat Nov 13, 2021 2:48 pm
and second run?
Instant, as always
BK201 wrote: Sat Nov 13, 2021 2:51 pm Instant, as always
Many users had a big delay even on second start, now it's fixed (by QT team). On my (not recent) computer W10 pro 20H2, the first run starts after max 2s.
I've checked on a virtual w10 (so very slow), and the first start is about 3s.
I don't understand why you have such delay...
BK201
Post by BK201 »
xnview wrote: Sun Nov 14, 2021 1:00 pm
I've provided all I can last time, but your team didn't found out the cause
I think you need to make a better debugger that can tell you why with detailed log
BK201 wrote: Sun Nov 14, 2021 1:04 pm I've provided all I can last time, but your team didn't found out the cause
Your realise that Pierre's "team" consists of only one person, Pierre, the developer of all XnView software products since t = minus infinity? :D
BK201 wrote: Sun Nov 14, 2021 1:04 pm I think you need to make a better debugger that can tell you why with detailed log
The problem is not from XnView's side, but QT
BK201
Post by BK201 »
xnview wrote: Mon Nov 15, 2021 8:13 am
So you've located the bug and confirmed it's bug of qt not xnview assets?
If it is, what is this "QT" you're talking about? What kind of "QT" library/component/plugin xnview are using? Who should I contact for? Where can I submit issue for this "QT"?
Moderator & Librarian
BK201 wrote: Mon Nov 15, 2021 9:26 am
xnview wrote: Mon Nov 15, 2021 8:13 amThe problem is not from XnView's side, but QT
:arrow: Wikipedia: Qt framework
BK201
Post by BK201 »
XnTriq wrote: Mon Nov 15, 2021 10:00 am
OK, so it's some sort of framework?
I found this site but submit issue require qt version, component and a qt developer account, how should I know? Is it correct that me, an end user, go mess with this?
BK201 wrote: Mon Nov 15, 2021 10:33 amOK, so it's some sort of framework?
As mentioned in his previous posts, Pierre has already reported the issue to the QT team.
@Pierre: So far, I haven't experienced a slow start-up of any Qt-based application – be it on Windows 2000, XP, 7 or 10.
BK201
Post by BK201 »
XnTriq wrote: Mon Nov 15, 2021 12:00 pm
OK, thanks for the info
I just want to help and provide log or something to developers to help locating the bug
I'm not sure how this happens and I'm afraid that it's a bug only on me so it won't get fixed for ever if I didn't upload related logs since I didn't saw anyone reporting the same bug on forum
The slow start is bothering me for like 10 years...
BK201 wrote: Mon Nov 15, 2021 12:07 pmOK, thanks for the info
I can assure you that Pierre appreciates your input – especially since you are an advanced user.
