Does somebody know, how to use the latest Riot Optimizer Version 1.x (64bit) in XnView MP? I did not find any instruction to use it in XnViewMP.
Since Version 0.98.2 of XnViewMP you can read/write the latest JPEG XL Format.
I read many things about the new format, but woud like to know, which JPEG XL compression is used.
Does it save files loseless or lossy? I do not see any switch to choose the compression ratio.
XnviewMP 0.98.2 - Riot Plugin / JPEG XL writing
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XN-View 2.51.2 | XnViewMP 1.5.5 | XnConvert 1.98 | Adobe Photoshop Elements 2023 | Elements XXL 10 | Paint.Net
Re: XnviewMP 0.98.2 - Riot Plugin / JPEG XL writing
Put the Riot plugin in AddOn folder
currently, losslessSince Version 0.98.2 of XnViewMP you can read/write the latest JPEG XL Format.
Thank you!
I also saw that the JPEG XL support was added in 0.97.0 but I cannot find it under version 0.98.2 on macOS (installed from Homebrew), is that normal? Thanks.
