Importing Photos with TWAIN
Phobos88
Post by Phobos88 »
Hey guys,
i am experiencing a strange issue.
With Windows 10 Build 20H2 i am not able to import my photos anymore via TWAIN.
I can select my source but when trying to import no photos show up when i try to do it a second time xnview.exe fails und closes immediately.
Then i tried a notebook with Windows 10 Build 1903 everything works, see file attached.
Does anyone else have this issue?
Kind regards!
Re: Importing Photos with TWAIN
I have no problem on 10 Build 20H2, which WIA settings do you use?
Phobos88
Post by Phobos88 »
Hey,
please see attached.
WIA Setting.png (8.14 KiB) Viewed 4028 times
settings before this dialog?
Phobos88
Post by Phobos88 »
which settings do you mean?
this one
Phobos88
Post by Phobos88 »
Same settings like you.
When starting the import the application "wiawow64.exe" crashes, see screenshot attached.
It does not work on any device with Windows 10 20H2.
No problem here on 10 20H2
Phobos88
Post by Phobos88 »
Ok, this is annoying. But thanks for your support nontheless!
