"-jpegtrans exif" disturbs "-resize"
Peter2
Post by Peter2 »
I have a command with uses "-resize" and "-rotate" (and some more), and it seems that "-jpegtrans exif" disturbs "-resize". When I use a simple "-rotate", then the resizing works fine.
No resizing:
nconvert.exe" -keepfiledate -q 100 -out jpeg -ratio -rtype lanczos -rflag decr -resize longest 2000 -jpegtrans exif -iptc_set 80 "8" -iptc_set 90 "7" -iptc_set 116 "test" -iptc_set 120 "alt" -o "c:\tempg\2000_20120507_002.jpg"   "D:\xxx\foto\x\IMG_3259.JPG"
Resizing OK:
nconvert.exe" -keepfiledate -q 100 -out jpeg -ratio -rtype lanczos -rflag decr -resize longest 2000 -iptc_set 80 "8" -iptc_set 90 "7" -iptc_set 116 "test" -iptc_set 120 "6" -o "c:\tempg\end_20120507_001.jpg"   "D:\xxx\foto\x\IMG_3259.JPG"
nconvert.exe" -keepfiledate -q 100 -out jpeg -ratio -rtype lanczos -rflag decr -resize longest 2000 -rotate 270 -iptc_set 80 "8" -iptc_set 90 "7" -iptc_set 116 "test" -iptc_set 120 "6" -o "c:\tempg\end_20120507_002.jpg"   "D:\xxx\foto\x\IMG_3260.JPG"
Re: "-jpegtrans exif" disturbs "-resize"
yes, jpegtrans doens't allow other operation
Peter2
Post by Peter2 »
xnview wrote: Thu Jan 28, 2021 11:39 am yes, jpegtrans doens't allow other operation
Thanks for answer, Pierre.
Please add this to the documentation (or to program message output).
