XnConvert (1.90) Fresh installation - missing files! Crash after start.
masterjp
Post by masterjp »
The XnConvert 64bit Installer does not contain all required files! XnConvert.exe does not start correctly.
The missing files are:
libssl-1_1-x64.dll
libcrypto-1_1-x64.dll
In the portable XnConvert 64bit zip file you can find the required files.
I unpacked the xnconvert 64bit.zip file and copied the missing files to program directory of xnconvert.
Now it works.
Please update the XnConvert Installer. Thank you!
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnConvert (1.90) Fresh installation - missing files! Crash after start.
i've updated the package please check?
masterjp
Post by masterjp »
Great. Now the installer contains the missing files and XnConvert works! Thanks.
