Please, don't post bugs or request in this topic!
You can download XnView MP 0.98.0 here:
Windows x32 ZIP version SHA256: AFC50E381017E2934DF3673F3EBF7E7DCA59258B3A711784859C67BD249C1F67
Windows x32 SETUP version SHA256: FA3F4BDEE78E9B9B6B61D24240C59163E94CE79D8966B7426E7D2C5EE87483DA
Windows x64 ZIP version SHA256: 466C8D798D4EA3E3489C4E953C857F87F7B0B9E02676893AB9AFC5DF85086A70
Windows x64 SETUP version SHA256: 0C8ECBDF5EA301DE987D324CBDC253CDD542B7B4A2ADC4326CC8A9F8374E9897
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: 706B8E0DFEA9EFAFC1B14413797AB594626BE79A1CF12EFE960E0862ED7116C0
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version SHA256: D818DCABD0F5BDDF6804F579F6BEF52EAC81F64F073241E0EB55D77F25890771
Linux x64 DEB version SHA256: C9A6C5FA3CB433B343A6EEF9DBCD26B89CC98AB194613E925F58424901ED477F
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.98.0:
1916: [New] Special label to show rating & color label - http://newsgroup.xnview.com/viewtopic.php?t=37766
1928: [New] 'Use original format' setting - http://newsgroup.xnview.com/viewtopic.php?t=41008
1926: [New] 'Show sbufolder' & update - http://newsgroup.xnview.com/viewtopic.php?t=35074
1925: [New] Capture: play sound setting
1923: [New] Icon when sidecar is used - http://newsgroup.xnview.com/viewtopic.php?t=38436
1922: [New] Categories filter (root) expanded state saved - http://newsgroup.xnview.com/viewtopic.php?t=37936
1920: [New] Menu item to toggle high zoom quality - http://newsgroup.xnview.com/viewtopic.php?t=37347
1913: [New] 'Save' as copy setting - http://newsgroup.xnview.com/viewtopic.php?t=40745
1912: [New] Left/Right button => Prev/Next file - http://newsgroup.xnview.com/viewtopic.php?t=40018
1910: [New] EXIF codec - http://newsgroup.xnview.com/viewtopic.php?t=41186
1909: [New] Batch convert: Drop shadow - direction - http://newsgroup.xnview.com/viewtopic.php?t=39888
1908: [New] Crop: Center - http://newsgroup.xnview.com/viewtopic.php?t=39395
1907: [New] Import: Counter per folder - http://newsgroup.xnview.com/viewtopic.php?t=39752
1905: [New] libjpeg-turbo 2.0.6
1904: [New] More template for duplicate file - http://newsgroup.xnview.com/viewtopic.php?t=40875
1903: [New] 'Save all' - http://newsgroup.xnview.com/viewtopic.php?t=41062
1902: [New] Video loop - http://newsgroup.xnview.com/viewtopic.php?t=40014
1899: [New] 'Select all files' - http://newsgroup.xnview.com/viewtopic.php?t=40810
1898: [New] Info pane: Empty tabs option - http://newsgroup.xnview.com/viewtopic.php?t=38204
1897: [New] Settings>Catalog - Check folders - http://newsgroup.xnview.com/viewtopic.php?t=41109
1895: [New] IPTC: merge option when importing template - http://newsgroup.xnview.com/viewtopic.php?t=37535
1894: [New] Search: for non categorized - http://newsgroup.xnview.com/viewtopic.php?t=39815
1893: [New] Copy/Move dialog: clear - http://newsgroup.xnview.com/viewtopic.php?t=40074
1891: [New] Scan headers setting - http://newsgroup.xnview.com/viewtopic.php?t=39113
1889: [New] WebP Animation - http://newsgroup.xnview.com/viewtopic.php?t=40549
1888: [New] mm in print size - http://newsgroup.xnview.com/viewtopic.php?t=41115
1887: [New] Slideshow: GIF playing - http://newsgroup.xnview.com/viewtopic.php?t=40970
1886: [New] Slideshow info position - http://newsgroup.xnview.com/viewtopic.php?t=41051
1881: [New] Batch convert: Mono mixer - http://newsgroup.xnview.com/viewtopic.php?t=39578
1877: [New] Small toolbar layout - http://newsgroup.xnview.com/viewtopic.php?t=41077
1876: [New] Display MWG-Regions and names on image - http://newsgroup.xnview.com/viewtopic.php?t=39741
1874: [New] Batch rename: reorder more than 1 file
1873: [New] Batch rename: Confirmation to delete templates - http://newsgroup.xnview.com/viewtopic.php?t=41033
1872: [New] Color model & Compression as placeholder - http://newsgroup.xnview.com/viewtopic.php?t=41026
1868: [New] Random file in edit mode - http://newsgroup.xnview.com/viewtopic.php?t=40337
1867: [New] XMP dialog - http://newsgroup.xnview.com/viewtopic.php?t=40080
1931: [Bug] Sidecar not deleted when viewing category - viewtopic.php?t=41204
1930: [Bug] Batch convert should not change global write format settings - http://newsgroup.xnview.com/viewtopic.php?t=41201
1929: [Bug] Set category create a sidecar without original XMP values
1927: [Bug] Ctrl+Right click in detail view - http://newsgroup.xnview.com/viewtopic.php?t=36951
1924: [Bug] ESC to quit - http://newsgroup.xnview.com/viewtopic.php?t=41135
1921: [Bug] Settings not propagated to Fullscreen's browser - http://newsgroup.xnview.com/viewtopic.php?t=37710
1919: [Bug] Favorites must not shown files
1918: [Bug] MacOS-Linux: File sorting error - http://newsgroup.xnview.com/viewtopic.php?t=40046
1917: [Bug] 16bits PNG + color profile - http://newsgroup.xnview.com/viewtopic.php?t=41196
1915: [Bug] Extension shown for folder - http://newsgroup.xnview.com/viewtopic.php?t=41192
1914: [Bug] Movie & playbar - http://newsgroup.xnview.com/viewtopic.php?t=41195
1911: [Bug] Transfer: XPTitle label - http://newsgroup.xnview.com/viewtopic.php?t=41183
1906: [Bug] Import: rename video file - http://newsgroup.xnview.com/viewtopic.php?t=39836
1901: [Bug] Drop files outside Xn on subfolder - http://newsgroup.xnview.com/viewtopic.php?t=40334
1900: [Bug] Change timestamp on video file - http://newsgroup.xnview.com/viewtopic.php?t=40150
1896: [Bug] GIF frame by frame - http://newsgroup.xnview.com/viewtopic.php?t=40023
1892: [Bug] Copy/Mode Dialog: show hidden setting - http://newsgroup.xnview.com/viewtopic.php?t=40422
1890: [Bug] Batch convert: AVIF params not saved - http://newsgroup.xnview.com/viewtopic.php?t=41150
1885: [Bug] AVIF settings - http://newsgroup.xnview.com/viewtopic.php?t=41134
1884: [Bug] Batch convert: Normalize Ex
1883: [Bug] Export: edit colormap crashs
1882: [Bug] Rating/color not imported from Classic - http://newsgroup.xnview.com/viewtopic.php?t=41108
1880: [Bug] GPS>Satellite crash on Windows
1879: [Bug] Favorite: Folder can't be deleted - http://newsgroup.xnview.com/viewtopic.php?t=39851
1878: [Bug] Setting for showing rating - http://newsgroup.xnview.com/viewtopic.php?t=40908
1875: [Bug] Edit comment doesn't update the view info correctly
1871: [Bug] Batch convert: change color depth & alpha - http://newsgroup.xnview.com/viewtopic.php?t=40680
1870: [Bug] Custom sort - http://newsgroup.xnview.com/viewtopic.php?t=41084
1869: [Bug] Crop: selection size - http://newsgroup.xnview.com/viewtopic.php?t=41047
1866: [Bug] Batch convert: Resize slow - http://newsgroup.xnview.com/viewtopic.php?t=41044
1865: [Bug] Batch convert: \# => \\# in filename
Changelog 0.97.1:
1863: [New] Capture rectangle on second screen - http://newsgroup.xnview.com/viewtopic.php?t=40830
1862: [New] Capture on second screen - http://newsgroup.xnview.com/viewtopic.php?t=37603
1854: [New] '#' can be escaped by '\#' - http://newsgroup.xnview.com/viewtopic.php?t=40917
1864: [Bug] HEIF leaks on MacOS
1861: [Bug] Pan tool - http://newsgroup.xnview.com/viewtopic.php?t=40918
1860: [Bug] Thumbnail border size & alpha - http://newsgroup.xnview.com/viewtopic.php?t=40868
1859: [Bug] Search: Pathname & catalog - http://newsgroup.xnview.com/viewtopic.php?t=40910
1858: [Bug] 'Select All' & Focus - http://newsgroup.xnview.com/viewtopic.php?t=40993
1857: [Bug] Catalog wrong files count - http://newsgroup.xnview.com/viewtopic.php?t=40947
1856: [Bug] Batch convert: crash Resize by Mpixels
1855: [Bug] Batch rename & Del don't work - http://newsgroup.xnview.com/viewtopic.php?t=40995
1853: [Bug] nbsp in tooltips
1852: [Bug] Ghostscript 9.53.x
1851: [Bug] Set/update category crash
Changelog 0.97.0:
1844: [New] Qt 5.15.0
1850: [New] IPTC: custom filename for template
1849: [New] MacOS: Internal video codec
1848: [New] Start in browser mode - viewtopic.php?f=82&t=40843
1847: [Bug] Offset repeat - viewtopic.php?f=62&t=40856
1846: [Bug] BLP - viewtopic.php?f=82&t=40862
1845: [New] JPEG XL
1842: [New] HEIF
1840: [Bug] 'select all' & focus - viewtopic.php?f=62&t=40834
1839: [New] LIBPNG 1.6.37
1838: [New] VS 2019 build
1837: [New] SQLite 3.33.0
1836: [New] XMP Toolkit
1835: [New] OpenJPEG 2000
1834: [New] LCMS 2.11
XnView MP 0.98.0
XnView MP 0.98.0
Re: XnView MP 0.98.0
Everyone, this is a fantastic release! Try out the new "Random File" feature!
Go to Tools > Settings > Interface > Shortcuts > Viewer mode > Random file > Shortcut for selected action > Custom
Assign it the custom keyboard shortcut: 0 ("zero" on your NumPad).
Now when you are viewing images with the Viewer, you can use:
Since the "0" key is next to the arrow keys on most keyboards, this makes it convenient and easy to use! Try it out yourselves, I think you'll like it!
- Left Arrow to view previous image
- Right Arrow to view next image
- 0 to view random image
