We need to Convert the Grayscale TIFF into Black & White TIFF as per the following specification:
Input: TIFF (Grayscale, LZW Compression, version 6.0)
Output: TIFF
Color Mode: Black & White
Compression: CCITT Group 4,
TIFF Version: 6.0
TIFF tag: Date and time of image creation (Code: 306)
We have tried to converting the above format using some application, the Date and time tag is removing after saving CCITT Group 4 compression. Customer required to retain the Date & time tag in the Black & White TIFF image with CCITT Group 4 compression.
When using XnView TIFF 6.0 is changed as 5.0 and not retaining the Date Time tag.
So Kindly let us know any application for converting Group 4 compression with Date Time TIFF tag.
Thanks in Advance
TIFF CCITT Group 4 Compression
Re: TIFF CCITT Group 4 Compression
For batch conversion XnConvert has an option on the Output tab 'Keep original date/time attributes' which should, subject to confirmation if you test it, preserve the date and time tag of the input files.
I'm not sure concerning TIFF 5 and 6, I thought 6 is very much the norm now, and I believe it is used in XnView software including XnConvert.
XnConvert use is reasonably self-explanatory if you work your way along the tabs from left to right.
