Colors for Thumbnails, Overlay Icons size
Post by michel038 »
Sometimes, I try to find at a glance photos containing GPS data
Or photos with missing XMP data ...
With coloured icons, it would be much easier to see if a colour is missing, rather than grey small text !
See an example of colours on the right side
Thanks
Re: Colors for Thumbnails, Overlay Icons
you can add your own image file in icons folder
Post by michel038 »
I can't find icons folder
Don't know either the name of the file I must look for, or the name of png files I could add ?
The only folder is ... \XnViewMP\UI\icons-48\
and in this folder , there are 141 png files, but none for iptc xmp exif gps ....
Post by michel038 »
That's it
I created a "icons" folder under Xnviewmp
It works, I can change colours !
Thank you
Re: Colors for Thumbnails, Overlay Icons [solved ... or not ?]
Post by michel038 »
V0.98 : a new overlay icon is added for XMP sidecar files
Is your info.png template modified ?
michel038 wrote: Mon Dec 14, 2020 5:45 pm V0.98 : a new overlay icon is added for XMP sidecar files
yes
Post by michel038 »
Ok, thank you
We have to reduce height to 11 pixels, and width 165 px.
(anyone can copy this sample, and paste it into icons folder )
Another version :
blizeH
Post by blizeH »
michel038 wrote: Thu Dec 31, 2020 5:20 pm Ok, thank you
Another version :info.png
Thanks! I love these, but unfortunately despite putting them into UI/icons-48 they're still showing as the old grey style icons for me... any idea what I'm doing wrong please? :(
Re: Colors for Thumbnails, Overlay Icons [solved]
Post by michel038 »
Create a new folder named "icons" ... and use this one, instead of using existing folders
Copy info.png into this folder
restart XnViewMp
blizeH
Post by blizeH »
Thank you! :) I've done that, is there a setting or a place to point the application to the new folder?
Post by michel038 »
sorry, I've forgotten to say "icons" folder must be in xnviewmp installation folder
Are you using windows ? Is Xnviewmp installed in C:\Program Files\Xnviewmp ?
in this configuration, info.png must be placed in C:\Program Files\Xnviewmp\icons\ , and is automatically used .
blizeH
Post by blizeH »
Oh yay! Thanks so much - I had the icons folder in /UI/ :) It's working perfectly now!
Moderator & Librarian
What are the correct dimensions for info.png and info@2x.png?
Related bug report: Overlay icon for sidecar files
Re: Colors for Thumbnails, Overlay Icons size
Post by michel038 »
On another PC (Windows 7 ), I'm using a new install of XnViewMP 1.3 (Zip version)
my coloured info.png is located in C:\xnviewmp\icons\
... but XnViewMP does not use it ... :shock: why ?
I tried a 165x11 pixels , and 330x22 pix ...
What is the purpose of double size info.png ? How should it be named if used ?
Windows display is set at 125%
Post by michel038 »
When I set Windows display to 100% , it works, I get colours.
When I set back to 125%, default icons are displayed.
But on this PC, 125% is required.
Is there a workaround ?
