Invert black and white
Is there an easy way to invert black and white on a file (not negative, only black and white)?
Re: Invert black and white
Thank you, but I mean:
To reverse black and white values of the image.
This inversion will change only the pixels that are either pure white or pure black.
The use is for printing of the images with black background (screenshots from programs).
You may get somewhere close to the change you need using [XnView MP settings]:rizarefaldi wrote: Thu May 20, 2021 12:53 pmhi, i got the same issue, please update the thread if you got the solusion, thanks.w64bit wrote: Thu Dec 03, 2020 10:50 am Thank you, but I mean:
1. Image > Map > Negative
2. Image > Adjust > Levels... [Move top right slider to left]
Is it possible, please, to add this feature (to reverse only black and white values of the image)?
Thank you
Thank you
