Images not realized as "Image" (Solved)
Peter2
Post by Peter2 »
In the Browser, in "Details view", I have some
- Bitmaps, defined as "Bitmap Image" and not as "Windows Bitmap"
- Icons, , defined as "Icon" and not as "ICO"
- PNG, , defined as "PNG Image" and not as "Portable Network Graphics"
When I set the Filter to "Images", they are not displayed.
Why? What's wrong with them?
They can be displayed, but saving them makes problems ..
I attach some examples - maybe the mystery can be explained
strange_images.zip
(2.77 KiB) Downloaded 31 times
Re: Images not realized as "Image"
the extensions are not good, for example the .bmp is a PNG
Peter2
Post by Peter2 »
xnview wrote: Sat Nov 07, 2020 12:45 pm the extensions are not good, for example the .bmp is a PNG
Thanks!
