Preview Alpha Channel in XnView Classic is broken
esenthel
Post by esenthel »
Latest release broke previewing images with alpha channels.
Press M to see alpha channel (show mask menu) doesn't always work, sometimes you need to press Ctrl+H first (Use Alpha Channel)
Re: Preview Alpha Channel in XnView Classic is broken
could you send me a picture file where it doesn't work?
esenthel
Post by esenthel »
In latest version 2.49.4
Please use any image that has alpha channel, BMP, PNG, TGA, any
Then set zoom to be less than 100%, for example 50%,
Then press M key to show alpha, it won't work
Zoom in at 100%, alpha starts to work
In options I have "High Quality Zoom \ Reduce = ON"
it works here
esenthel
Post by esenthel »
esenthel wrote: Sun Nov 08, 2020 7:01 am It's broken 100%
https://youtu.be/H5jyZxcHdUI
I can't reproduce, could you send me the file used, and which settings do you have in options>View?
esenthel
Post by esenthel »
The problem happens with any/all images that have alpha channel.
it's crazy, it works correctly here
esenthel
Post by esenthel »
Could it be related to Windows?
I have the latest version: Win 10 Home, ver 2004, os build 19041.508
But I've tested an older version, 2.37 just now, and it doesn't suffer from the same problem.
So I think something got broken in your code.
It was working fine just couple releases ago.
Is there a way to download older versions of your software? (v 2.48, 2.47 or something)
I could tell you between each release where the problem occurred, and you could check your code base for changes in that time frame, to see which change broke this function.
esenthel wrote: Thu Dec 03, 2020 5:30 am Could it be related to Windows?
no it's XnView
http://download.xnview.com/old_versions
Moderator & Librarian
I'm not able to reproduce this issue with XnView Classic v2.49.4 and 966_1578623403.png or any other 32-bit PNG. However, we had a similar report a couple of years ago.
Related: Recommended settings
esenthel
Post by esenthel »
I've tested a bunch of versions:
2.39 works great, no issue
2.40 has different problem, black background and white pixels on the border
2.41+ has problems with alpha sometimes visible, sometimes RGB, depending on zoom < or > 100%
Something got broken between 2.39 and 2.40
Attaching the entire XnView.ini file with settings, maybe you can do tests with it.
My Windows DPI Settings in 125%
xnview.zip
(5.09 KiB) Downloaded 84 times
Hello esenthel
I ran XnView v2.49.4 with the INI you provided (Windows DPI = 120%) and opened flour-flower-png-transparent-png-images-pluspng-2.png in fullscreen, edit and preview. Although I watched your screen recording again and made sure to follow the steps outlined in one of your previous posts…
esenthel wrote: Fri Oct 23, 2020 4:34 amIn latest version 2.49.4
… everything works as expected :-?
Related: Transparent pixels dont get filtered correctly
