Seeking a way to use hotkey combo for tagging
kevin37
Post by kevin37 »
Hello everyone!
New to the forums :)
I've been searching and I need some help (couldn't find a solution).
I'm looking for a way to do a hot key or combination of keys to tag into IPTC.
I'm studying colors in photographs and want to tag them by what color harmony they use but can't find an easy and fast way to preview the image and apply the tag and move on.
Is there an easy solution in XnView?
Thanks so much!
Be safe!
Have a great weekend!
Cheers,
Kevin
Re: Seeking a way to use hotkey combo for tagging
you can select more than 1 picture file for IPTC dialog
kevin37
Post by kevin37 »
Hello!
Sorry to bother everyone, but does anyone have some clear tips/instructions on how to quickly tag an image with a short cut key combination?
Thanks so much!
Cheers,
Kevin
