Please, don't post bugs or request in this topic!
You can download XnView MP 0.96.5 here:
Windows x32 ZIP version SHA256: 00025E31C4D7187132C0881D5E458309F942F8404C9D43BFB4D31B343B5CF8DF
Windows x32 SETUP version SHA256: FB954428D07AFC56CC9E1EF0A94020A5DDF94C54FABB411BDDD551B82E8BE8D8
Windows x64 ZIP version SHA256: 3745D58A1A337EF5108497F6F09257193CB6008B1B6578535D5726F9BFF6315A
Windows x64 SETUP version SHA256: 5482F87F5FCE5847FFD99683196E6E4023D3711F118EAF50820926DE0EA70299
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: E3F3A6CB823D25584A84E712C275590D8C9064A2E453CE9D483CD04FB02C462A
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version SHA256: 89DEBFD1DA5227359963069ACCC995FA1F3272BEA6787890C22DBA682D75C09C
Linux x64 DEB version SHA256: BA89811E7CACC01A1389C716837BDC358A663B84D4BA7BCBEF348337D6AA5F44
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.96.5:
1828: [New] Paint: Ask close confirmation - http://newsgroup.xnview.com/viewtopic.php?t=40289
1826: [New] Batch Rename: Regexp & extension - http://newsgroup.xnview.com/viewtopic.php?t=40101
1825: [New] Catalog sortable column - http://newsgroup.xnview.com/viewtopic.php?t=40503
1816: [New] Canvas resize: Square - http://newsgroup.xnview.com/viewtopic.php?t=40591
1815: [New] Change timestamp: First/Last - http://newsgroup.xnview.com/viewtopic.php?t=40633
1833: [Bug] MacOS: contact sheet doesn't close dialog
1832: [Bug] MacOS: Rect capture
1831: [Bug] Set category by context menu doesn't create XMP sidecar
1830: [Bug] IPTC: ICC removed if 'XMP only' - http://newsgroup.xnview.com/viewtopic.php?t=40779
1829: [Bug] Toolbar: Set icon on command - http://newsgroup.xnview.com/viewtopic.php?t=33301
1827: [Bug] Hidden settings t hide quick filter - http://newsgroup.xnview.com/viewtopic.php?t=40385
1824: [Bug] Category not saved - http://newsgroup.xnview.com/viewtopic.php?t=40718
1823: [Bug] RAW orientation after editing - http://newsgroup.xnview.com/viewtopic.php?t=40716
1822: [Bug] Description on files with different folder (search) - http://newsgroup.xnview.com/viewtopic.php?t=40660
1821: [Bug] ESC key when saving image
1820: [Bug] SGI RGB problem - http://newsgroup.xnview.com/viewtopic.php?t=40685
1819: [Bug] XCF layer visibility - http://newsgroup.xnview.com/viewtopic.php?t=40615
1818: [Bug] GPS data '°' - http://newsgroup.xnview.com/viewtopic.php?t=40640
1817: [Bug] PNG icon for toolbar - http://newsgroup.xnview.com/viewtopic.php?t=40674
1814: [Bug] Canon CR3 bad orientation - http://newsgroup.xnview.com/viewtopic.php?t=39478
1813: [Bug] Info rectangle has not good height when using html tags - http://newsgroup.xnview.com/viewtopic.php?t=39881
1812: [Bug] Display crash
Changelog 0.96.4:
1811: [Bug] crash at startup with a file
1810: [Bug] Batch convert: 64 colors doesn't work - viewtopic.php?t=40618
1809: [Bug] PSD: IPTC not correctly written
Changelog 0.96.3:
1808: [Bug] MacOS: Exiting fullscreen - viewtopic.php?f=62&t=40366
1807: [Bug] Catalog remove folders don't update categories count - viewtopic.php?f=62&t=40569
1806: [Bug] Search: embedded comment - viewtopic.php?f=82&t=40566
1805: [Bug] Paint: Integer font size
1804: [Bug] Rating operator selected - viewtopic.php?f=82&t=40530
1803: [Bug] Category sets & apostrophe - viewtopic.php?f=62&t=40515
1802: [Bug] 'File size' not shown in thumbnails labels
1801: [Bug] Filters doesn't work if 'Recognize by Ext' - viewtopic.php?f=62&t=40459
1800: [New] XMP available for template in Batch rename, Print & File listing
1799: [Bug] Export: Auto refresh - viewtopic.php?f=62&t=40467
1798: [Bug] HPI alpha
1797: [Bug] Slow issues when using large categories database - viewtopic.php?p=163116
1796: [Bug] AI/PDF XMP metadata - viewtopic.php?f=82&t=40445
1795: [Bug] 'Show tagged files' toggle - Normal list <-> Tagged list
1707: [Bug] Multiple spaces in Info view - viewtopic.php?f=82&t=39881
1794: [Bug] Search: add doesn't work - viewtopic.php?f=62&t=40446
1793: [Bug] Save rotated image & orientation field - viewtopic.php?f=62&t=30709
1792: [Bug] {Categories} not shown for video files - viewtopic.php?p=162799#p162912
1791: [Bug] Batch convert: Params not saved in Levels - viewtopic.php?f=62&t=40440
1790: [Bug] Filter not applied to rectangle selected
1789: [Bug] Favorites: Problem when having only orphaned folder
1788: [Bug] Paint: border around background - viewtopic.php?f=83&t=40421
1787: [Bug] 'Auto image size' when browsing images quickly - viewtopic.php?f=62&t=40414
Changelog 0.96.2:
1786: [Bug] MacOS: Space setting - http://newsgroup.xnview.com/viewtopic.php?t=40310
1785: [Bug] MacOS: Dark theme - http://newsgroup.xnview.com/viewtopic.php?t=40381
1784: [Bug] MacOS: Problems in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=40342
1783: [Bug] Codepage for embedded comment in 'Info'
1782: [Bug] CSS style not working in 'Info' - http://newsgroup.xnview.com/viewtopic.php?t=40351
1781: [Bug] Crash on XCF - http://newsgroup.xnview.com/viewtopic.php?t=40000
1780: [Bug] Codec for embedded comment
1779: [Bug] Batch convert: 'Same as original' no more here - http://newsgroup.xnview.com/viewtopic.php?t=40333
1778: [Bug] Batch convert: Wrong counting of read-only files - http://newsgroup.xnview.com/viewtopic.php?t=40316
1777: [Bug] 'Convert into' doesn't keep metadata
1776: [Bug] {Categories} not correct - http://newsgroup.xnview.com/viewtopic.php?t=40278
Changelog 0.96.1:
1775: [New] Batch convert: 'save log' menu - viewtopic.php?f=79&t=40250
1772: [New] Batch convert: Extensions for hot folders - viewtopic.php?f=79&t=39838
1746: [New] Search: in pathname - viewtopic.php?f=95&t=38591
1761: [New] Search: restore last search
1774: [Bug] Message if catalog or metadata exporting is disabled - viewtopic.php?f=62&t=40139
1773: [Bug] Crash when load animated GIF & save as jpeg
1771: [Bug] Batch convert: output format x2 - viewtopic.php?f=79&t=40244
1770: [Bug] Paint: Wrong tab by default - viewtopic.php?f=62&t=40297
1769: [Bug] Batch convert: resize by 'Height' ignore value - viewtopic.php?f=62&t=40190
1767: [Bug] Open filelist & UTF8 - viewtopic.php?f=62&t=40275
1766: [Bug] Some thumbnails not loading - viewtopic.php?f=62&t=40277
1765: [Bug] Search: Catalog & 'base path' - viewtopic.php?f=62&t=40190
1764: [Bug] Batch convert: Crash with 'levels' - viewtopic.php?f=83&t=40252
1763: [Bug] Thumbnail Labels not updated after changing category - viewtopic.php?f=83&t=40147
1762: [Bug] After a file copy, thumbnail not displayed - viewtopic.php?f=82&t=39423
1630: [Bug] Resize image/canvas presets ignore 'keep ratio' setting - viewtopic.php?f=95&t=38581
1760: [Bug] F11 in browser + Alt+F4 crash - viewtopic.php?f=101&t=40194
1759: [Bug] Embedded thumbnail not rebuilt for JPEG
1758: [Bug] Wrong info - viewtopic.php?f=62&t=40178
1757: [Bug] 'Info' & spaces - viewtopic.php?f=62&t=40170
1756: [Bug] Unicode lepton files - viewtopic.php?f=62&t=40159
1755: [Bug] Some WebP can't be loaded
Changelog 0.96:
1752: [New] AVIF support - viewtopic.php?t=38649
1750: [New] Experimental 'Fit window to image' - viewtopic.php?=40137
1747: [New] Search: category contains/does not contain/is
1746: [New] Search: in pathname - viewtopic.php?t=38591
1739: [New] Capture: Hide Xn - viewtopic.php?t=39511
1735: [New] Compare: shortcuts - viewtopic.php?t=39844
1733: [New] Paste keep ratio - viewtopic.php?t=39779
1727: [New] Show info always visible - viewtopic.php?t=39490
1726: [New] Batch convert: 'Close after conversion' - viewtopic.php?t=39403
1724: [New] Paste special - viewtopic.php?t=39572
1721: [New] Paint: Background color for Text - viewtopic.php?t=39889
1720: [New] 'New image' in image mode - viewtopic.php?t=39942
1719: [New] Copy/Paste GPS data - viewtopic.php?t=36962
1718: [New] Width/Height in mm placeholder - viewtopic.php?t=39847
1717: [New] Batch Convert: Numeric numerator + output filename available in "Text" - viewtopic.php?t=39996
1714: [New] Batch convert: White balance
1754: [Bug] Move file & excluded folder - viewtopic.php?t=38426
1753: [Bug] Save a screenshot, statusbar not updated
1751: [Bug] MacOS: Translation of standard buttons
1749: [Bug] Rename & companion file - viewtopic.php?t=39613
1748: [Bug] Not possible to overwrite embedded thumbnail on some JPEG
1745: [Bug] Rename field not visible in thumbnail view mode - viewtopic.php?t=39514
1744: [Bug] Maximum view tab not work - viewtopic.php?t=39536
1743: [Bug] Auto Correct doesn't work correct-ly - viewtopic.php?t=39709
1742: [Bug] Search Similar: can't close dialog - viewtopic.php?t=39314
1741: [Bug] Import: aae not copied - viewtopic.php?t=38795
1740: [Bug] {File type} place holder - viewtopic.php?t=39272
1738: [Bug] Transfer: Multiple lines - viewtopic.php?t=39875
1737: [Bug] Batch rename: spacing between columns - viewtopic.php?t=39874
1736: [Bug] Open second image & fullscreen - viewtopic.php?t=39676
1734: [Bug] "Properties" column shows incorrect # of colors - viewtopic.php?t=39894
1732: [Bug] Compare: close view - viewtopic.php?t=39819
1731: [Bug] Compare: Cannot turn off "Confirm file delete" - viewtopic.php?t=39870
1730: [Bug] Windows taskbar text - viewtopic.php?t=39826
1729: [Bug] Placeholder & Current date - viewtopic.php?t=39790
1728: [Bug] Tooltips on category - viewtopic.php?t=39667
1725: [Bug] GPS in detail view - viewtopic.php?t=39686
1723: [Bug] File Listing: Append to file - viewtopic.php?t=39797
1722: [Bug] Unknown file info not shown in toolbar - viewtopic.php?t=40091
1716: [Bug] Image viewer slow with big folder - viewtopic.php?t=40012
1715: [Bug] Slideshow: window doesn't close
1713: [Bug] Customized format text color not used in 'details'
1712: [Bug] Cut and paste files on selected folder can delete original files - viewtopic.php?t=40053
1711: [Bug] Film simulation crash
1710: [Bug] Windows: if drive letter is lower case in pathname, duplicate entry in catalog
1709: [Bug] MacOSX: Folder without subfolder can have arrow to expand
1708: [Bug] Sharpen setting not used for folder's thumbnail - viewtopic.php?t=39916
1707: [Bug] Multiple spaces in Info view - viewtopic.php?t=39881
Changelog 0.95:
1706: [New] Qt 5.12.6
Changelog 0.94.3:
1705: [New] Batch convert - 'Transparent color'
1704: [Bug] Font size in Fusion theme - viewtopic.php?t=39872
1703: [Bug] EXIF user comment - viewtopic.php?t=39873
Changelog 0.94.2:
1700: [New] 'Remove alpha' - viewtopic.php?t=39592
1694: [New] Video date - viewtopic.php?t=39739
1702: [Bug] GS 9.50 un*x - viewtopic.php?t=39753
1701: [Bug] zoom field keep focus - viewtopic.php?&t=39627
1699: [Bug] Thumbnails not loaded at startup - viewtopic.php?t=39754
1698: [Bug] Companion files deleted in edit mode, setting not used - viewtopic.php?t=39587
1697: [Bug] Categories not updated if file (IPTC) modified outside - viewtopic.php?t=39546
1696: [Bug] New files, no metadata - viewtopic.php?t=39690
1695: [Bug] Zoom field steals focus - viewtopic.php?t=39692
1693: [Bug] Compare similar content very slow - viewtopic.php?t=39695
1692: [Bug] Linux: Not all datas from ExifTools - viewtopic.php?t=39701
Changelog 0.94.1:
1691: [Bug] Problem with Ghostscript 9.50
1690: [Bug] Use file date if no exif date setting (useFileDateWhenNoExif in xnview.ini)
1689: [Bug] Browse categories result in fullscreen not possible - viewtopic.php?t=39638
1688: [Bug] Non image files not shown in browser
1687: [Bug] 'Edit IPTC' doesn't write fields - viewtopic.php?t=39620
XnView MP 0.96.5
XnView MP 0.96.5
Re: XnView MP 0.96.5
After update to this version the application needs several minutes to start and then other applications are hanging when xnviewmp starts. But all steps need a long time. Is there an log that i can post?
hello try my deb: http://wubijacq.com/rwd/xnviewmp-linux.php
on which OS?TommyD wrote: Fri Aug 21, 2020 4:02 pm After update to this version the application needs several minutes to start and then other applications are hanging when xnviewmp starts. But all steps need a long time. Is there an log that i can post?
