Color replacing doesn't work [Solved]
testperson
Post by testperson »
I tried to replace the color #ffffff by #f7f7f7. But on some of my images it just dont work. I tried it with the batch option of both XnView Classic and XnConverter.
Here is one of those images that failed:
Any ideas why its not working?
Re: Color replacing doesn't work
testperson wrote: Thu Jul 30, 2020 4:11 pm I tried to replace the color #ffffff by #f7f7f7. But on some of my images it just dont work. I tried it with the batch option of both XnView Classic and XnConverter.
The file you uploaded is a 1-bit black and white image, so only colours RGB 000000 and FFFFFF are supported, you would presumably have to convert it to 24-bit depth before replacing FFFFFF...
testperson
Yes, that was the issue, thanks a lot :)
