Please, don't post bugs or request in this topic!
You can download XnView MP 0.96.3 here:
Windows x32 ZIP version SHA256: 006FDB37CB164B6BA0266006B12D7878EF108EC95BE6B7BECAE38A86F76D4A9F
Windows x32 SETUP version SHA256: A3F7D83D77C850279C9C8B504435306CA84B5D7E16CE0C77E3A418ACCE573825
Windows x64 ZIP version SHA256: A197993390F93C3BCF04F6F765BE732E059E723B4D5DF8467B547AC3808FE2F2
Windows x64 SETUP version SHA256: DE0F10F4CF951E0C5844B44095F1E28078D1AC40F392B5C11122039CE2996EBA
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: C41BFC469E036FC64EA7FF4B66E07D1EB9B0B0C542A4CE40108794D0B58EE3C7
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version SHA256: FD5A5C5D35F803063E33E24C4AC8EB400274E38A24845957AB76B715857E21EA
Linux x64 DEB version SHA256: 6739114CD4DE9B7F9E045D4FE92AA587753B75413B913771EB619EB63779E6CF
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.96.3:
1808: [Bug] MacOS: Exiting fullscreen - viewtopic.php?f=62&t=40366
1807: [Bug] Catalog remove folders don't update categories count - viewtopic.php?f=62&t=40569
1806: [Bug] Search: embedded comment - viewtopic.php?f=82&t=40566
1805: [Bug] Paint: Integer font size
1804: [Bug] Rating operator selected - viewtopic.php?f=82&t=40530
1803: [Bug] Category sets & apostrophe - viewtopic.php?f=62&t=40515
1802: [Bug] 'File size' not shown in thumbnails labels
1801: [Bug] Filters doesn't work if 'Recognize by Ext' - viewtopic.php?f=62&t=40459
1800: [New] XMP available for template in Batch rename, Print & File listing
1799: [Bug] Export: Auto refresh - viewtopic.php?f=62&t=40467
1798: [Bug] HPI alpha
1797: [Bug] Slow issues when using large categories database - viewtopic.php?p=163116
1796: [Bug] AI/PDF XMP metadata - viewtopic.php?f=82&t=40445
1795: [Bug] 'Show tagged files' toggle - Normal list <-> Tagged list
1707: [Bug] Multiple spaces in Info view - viewtopic.php?f=82&t=39881
1794: [Bug] Search: add doesn't work - viewtopic.php?f=62&t=40446
1793: [Bug] Save rotated image & orientation field - viewtopic.php?f=62&t=30709
1792: [Bug] {Categories} not shown for video files - viewtopic.php?p=162799#p162912
1791: [Bug] Batch convert: Params not saved in Levels - viewtopic.php?f=62&t=40440
1790: [Bug] Filter not applied to rectangle selected
1789: [Bug] Favorites: Problem when having only orphaned folder
1788: [Bug] Paint: border around background - viewtopic.php?f=83&t=40421
1787: [Bug] 'Auto image size' when browsing images quickly - viewtopic.php?f=62&t=40414
Changelog 0.96.2:
1786: [Bug] MacOS: Space setting - http://newsgroup.xnview.com/viewtopic.php?t=40310
1785: [Bug] MacOS: Dark theme - http://newsgroup.xnview.com/viewtopic.php?t=40381
1784: [Bug] MacOS: Problems in fullscreen - http://newsgroup.xnview.com/viewtopic.php?t=40342
1783: [Bug] Codepage for embedded comment in 'Info'
1782: [Bug] CSS style not working in 'Info' - http://newsgroup.xnview.com/viewtopic.php?t=40351
1781: [Bug] Crash on XCF - http://newsgroup.xnview.com/viewtopic.php?t=40000
1780: [Bug] Codec for embedded comment
1779: [Bug] Batch convert: 'Same as original' no more here - http://newsgroup.xnview.com/viewtopic.php?t=40333
1778: [Bug] Batch convert: Wrong counting of read-only files - http://newsgroup.xnview.com/viewtopic.php?t=40316
1777: [Bug] 'Convert into' doesn't keep metadata
1776: [Bug] {Categories} not correct - http://newsgroup.xnview.com/viewtopic.php?t=40278
Changelog 0.96.1:
1775: [New] Batch convert: 'save log' menu - viewtopic.php?f=79&t=40250
1772: [New] Batch convert: Extensions for hot folders - viewtopic.php?f=79&t=39838
1746: [New] Search: in pathname - viewtopic.php?f=95&t=38591
1761: [New] Search: restore last search
1774: [Bug] Message if catalog or metadata exporting is disabled - viewtopic.php?f=62&t=40139
1773: [Bug] Crash when load animated GIF & save as jpeg
1771: [Bug] Batch convert: output format x2 - viewtopic.php?f=79&t=40244
1770: [Bug] Paint: Wrong tab by default - viewtopic.php?f=62&t=40297
1769: [Bug] Batch convert: resize by 'Height' ignore value - viewtopic.php?f=62&t=40190
1767: [Bug] Open filelist & UTF8 - viewtopic.php?f=62&t=40275
1766: [Bug] Some thumbnails not loading - viewtopic.php?f=62&t=40277
1765: [Bug] Search: Catalog & 'base path' - viewtopic.php?f=62&t=40190
1764: [Bug] Batch convert: Crash with 'levels' - viewtopic.php?f=83&t=40252
1763: [Bug] Thumbnail Labels not updated after changing category - viewtopic.php?f=83&t=40147
1762: [Bug] After a file copy, thumbnail not displayed - viewtopic.php?f=82&t=39423
1630: [Bug] Resize image/canvas presets ignore 'keep ratio' setting - viewtopic.php?f=95&t=38581
1760: [Bug] F11 in browser + Alt+F4 crash - viewtopic.php?f=101&t=40194
1759: [Bug] Embedded thumbnail not rebuilt for JPEG
1758: [Bug] Wrong info - viewtopic.php?f=62&t=40178
1757: [Bug] 'Info' & spaces - viewtopic.php?f=62&t=40170
1756: [Bug] Unicode lepton files - viewtopic.php?f=62&t=40159
1755: [Bug] Some WebP can't be loaded
Changelog 0.96:
1752: [New] AVIF support - viewtopic.php?t=38649
1750: [New] Experimental 'Fit window to image' - viewtopic.php?=40137
1747: [New] Search: category contains/does not contain/is
1746: [New] Search: in pathname - viewtopic.php?t=38591
1739: [New] Capture: Hide Xn - viewtopic.php?t=39511
1735: [New] Compare: shortcuts - viewtopic.php?t=39844
1733: [New] Paste keep ratio - viewtopic.php?t=39779
1727: [New] Show info always visible - viewtopic.php?t=39490
1726: [New] Batch convert: 'Close after conversion' - viewtopic.php?t=39403
1724: [New] Paste special - viewtopic.php?t=39572
1721: [New] Paint: Background color for Text - viewtopic.php?t=39889
1720: [New] 'New image' in image mode - viewtopic.php?t=39942
1719: [New] Copy/Paste GPS data - viewtopic.php?t=36962
1718: [New] Width/Height in mm placeholder - viewtopic.php?t=39847
1717: [New] Batch Convert: Numeric numerator + output filename available in "Text" - viewtopic.php?t=39996
1714: [New] Batch convert: White balance
1754: [Bug] Move file & excluded folder - viewtopic.php?t=38426
1753: [Bug] Save a screenshot, statusbar not updated
1751: [Bug] MacOS: Translation of standard buttons
1749: [Bug] Rename & companion file - viewtopic.php?t=39613
1748: [Bug] Not possible to overwrite embedded thumbnail on some JPEG
1745: [Bug] Rename field not visible in thumbnail view mode - viewtopic.php?t=39514
1744: [Bug] Maximum view tab not work - viewtopic.php?t=39536
1743: [Bug] Auto Correct doesn't work correct-ly - viewtopic.php?t=39709
1742: [Bug] Search Similar: can't close dialog - viewtopic.php?t=39314
1741: [Bug] Import: aae not copied - viewtopic.php?t=38795
1740: [Bug] {File type} place holder - viewtopic.php?t=39272
1738: [Bug] Transfer: Multiple lines - viewtopic.php?t=39875
1737: [Bug] Batch rename: spacing between columns - viewtopic.php?t=39874
1736: [Bug] Open second image & fullscreen - viewtopic.php?t=39676
1734: [Bug] "Properties" column shows incorrect # of colors - viewtopic.php?t=39894
1732: [Bug] Compare: close view - viewtopic.php?t=39819
1731: [Bug] Compare: Cannot turn off "Confirm file delete" - viewtopic.php?t=39870
1730: [Bug] Windows taskbar text - viewtopic.php?t=39826
1729: [Bug] Placeholder & Current date - viewtopic.php?t=39790
1728: [Bug] Tooltips on category - viewtopic.php?t=39667
1725: [Bug] GPS in detail view - viewtopic.php?t=39686
1723: [Bug] File Listing: Append to file - viewtopic.php?t=39797
1722: [Bug] Unknown file info not shown in toolbar - viewtopic.php?t=40091
1716: [Bug] Image viewer slow with big folder - viewtopic.php?t=40012
1715: [Bug] Slideshow: window doesn't close
1713: [Bug] Customized format text color not used in 'details'
1712: [Bug] Cut and paste files on selected folder can delete original files - viewtopic.php?t=40053
1711: [Bug] Film simulation crash
1710: [Bug] Windows: if drive letter is lower case in pathname, duplicate entry in catalog
1709: [Bug] MacOSX: Folder without subfolder can have arrow to expand
1708: [Bug] Sharpen setting not used for folder's thumbnail - viewtopic.php?t=39916
1707: [Bug] Multiple spaces in Info view - viewtopic.php?t=39881
Changelog 0.95:
1706: [New] Qt 5.12.6
Changelog 0.94.3:
1705: [New] Batch convert - 'Transparent color'
1704: [Bug] Font size in Fusion theme - viewtopic.php?t=39872
1703: [Bug] EXIF user comment - viewtopic.php?t=39873
Changelog 0.94.2:
1700: [New] 'Remove alpha' - viewtopic.php?t=39592
1694: [New] Video date - viewtopic.php?t=39739
1702: [Bug] GS 9.50 un*x - viewtopic.php?t=39753
1701: [Bug] zoom field keep focus - viewtopic.php?&t=39627
1699: [Bug] Thumbnails not loaded at startup - viewtopic.php?t=39754
1698: [Bug] Companion files deleted in edit mode, setting not used - viewtopic.php?t=39587
1697: [Bug] Categories not updated if file (IPTC) modified outside - viewtopic.php?t=39546
1696: [Bug] New files, no metadata - viewtopic.php?t=39690
1695: [Bug] Zoom field steals focus - viewtopic.php?t=39692
1693: [Bug] Compare similar content very slow - viewtopic.php?t=39695
1692: [Bug] Linux: Not all datas from ExifTools - viewtopic.php?t=39701
Changelog 0.94.1:
1691: [Bug] Problem with Ghostscript 9.50
1690: [Bug] Use file date if no exif date setting (useFileDateWhenNoExif in xnview.ini)
1689: [Bug] Browse categories result in fullscreen not possible - viewtopic.php?t=39638
1688: [Bug] Non image files not shown in browser
1687: [Bug] 'Edit IPTC' doesn't write fields - viewtopic.php?t=39620
XnView MP 0.96.3
XnView MP 0.96.3
Re: XnView MP 0.96.3
Thanks for all your efforts. I've been trying to download this version all afternoon. From the link on your web site, or from the link above, it gets about a third of the way through, and it reports: "The network connection was lost".
