change the units of image resolution
xnpro
Post by xnpro »
please add option to change the units of image resolution, like imagemagick convert -unit type (none, inches, cm) ?
thank you
Re: change the units of image resolution
for resize/canvas?
xnpro
Post by xnpro »
for resize
xnpro wrote: Sun Jun 28, 2020 7:36 amfor resize
i'll add the same as 'canvas resize', for example: -resize 100mm 200mm
