Problem with WMZ file format
Vlad_Sakh
Post by Vlad_Sakh »
XNView Classic version 2.49.2 is not able to open WMZ-files, while with
the version 1.99.6 — no problems. Tried several times. Tunes in both
versions are similar. Checkboxes "all available formats" and "wmz" itself
are activated. 2.49.2 even depicts XNView icon in file list, but double
click causes the message about unrecognizable file format.
Sincerely
Vladimir
P.S. If important — Windows 7 Pro (32).
Re: Problem with WMZ file format
Vlad_Sakh
Post by Vlad_Sakh »
xnview wrote: Wed Jun 17, 2020 2:54 pm could you send me a sample file?
Please, no problems. The PNG and WMZ pictures must be similar. Sorry for ZIP, but the forum engine refuses to add WMZ file itself.
Test_WMZ.zip
(67.02 KiB) Downloaded 139 times
the WMZ file seems not to be a WMF zip packed
Vlad_Sakh
Post by Vlad_Sakh »
xnview wrote: Thu Jun 25, 2020 2:15 pm the WMZ file seems not to be a WMF zip packed
Maybe so. But nevertheless 1.99.6 version overcomes it perfectly. If it's interesting, I'll explain how such files appear.
1. Insert Origin Graph picture into WORD document by means of "Copy Page" in Origin and "Special Insert" in WORD.
2. Save WORD document as HTML.
3. Open the appeared folder with the same name as WORD file containing graphs — the problem file will be there.
In any case, thank you for the reply. 1.99.6 version satisfies me, so I'll use it.
you are right, strange, i'll check...
