Multi image selection won't open for keywords
Phil_Rose
Post by Phil_Rose »
Hi. Can anyone tell me where the option is to make this stop stripping out my metadata? Thanks!
Bah. It won't show my image from Dropbox. https://www.dropbox.com/s/w9mty9pksyq5s ... 1.jpg?dl=0
It is a message saying 'Field values are not loaded because 'Do not load Field Values' is checked.
Moderator: You need to right-click on the image displayed in Dropbox, select 'Copy image address' and place that link between Img tags:
Maybe this will work. Yours didn't seem to... Image
Thanks! That seems better.
Phil_Rose
Re: Multi image selection won't open for keywords
Post by Phil_Rose »
Still hoping someone can help with this.
you have this message when using IPTC dialog, right?
Phil_Rose
Post by Phil_Rose »
Sorry, yes. I should have mentioned that.
Phil_Rose wrote: Mon Jun 01, 2020 11:13 pm Sorry, yes. I should have mentioned that.
you can uncheck the option in the dialog
Phil_Rose
Post by Phil_Rose »
Sorry, in what dialog? If I just say 'OK' then it won't load the field values but I want it to. Where can I uncheck 'Do not load field values'?
Oh, I found it but it still doesn't load the field values. Is that unavoidable?
the settings is uncheck, but values from image file are not loaded in the dialog??
Phil_Rose
Post by Phil_Rose »
Sorry for the slow reply. I did notice it after your last comment (thanks for that) and check marked it. So now that dialog does not pop up but when I have more than one item selected the Keywords field shows that there are no keywords applied. Is this expected behavior?
Thanks!
Phil
'don't load fields' is not checked, and iptc keywords are not loaded?
sennekkah
Post by sennekkah »
xnview wrote: Thu Jun 25, 2020 12:55 pm 'don't load fields' is not checked, and iptc keywords are not loaded?
I'm sorry to be a numbskull, but I'm unable to find the the check box labelled "do not load field values" in XnViewMP
Ver 1.6.1 (October 2023), so that I can uncheck it and do a batch edit of XMP data.
Thanks in advance
