Black output RAW to anything
Heerockss
Post by Heerockss »
WORKS WITH LATEST VERSION
Hello. First of all, thanks for this cool software!
I ran in a Problem while converting .cr3 RAW images to TIFF or WebP but its not limited to those two but happens to all formats.
Cause of the problem seems to be this: Settings>Load Format Settings...>Camera RAW>Use
As soon as i change it to Half Size or Full Size, the output is just an empty black image.
If i use embedded preview the output image is working but, as far as i understand it, xnConvert uses only the preview image data for conversion and not the actual RAW data, because the colors are way off after conversion.
I just wanted to let you know if this could be a bug, if it is working as intended (cause maybe xnConvert just cant handle RAW data), ignore this post or even delete it.
Cheers
Re: Black output RAW to anything
which RAW format?
Heerockss
Post by Heerockss »
Canon .CR3
Heerockss wrote: Fri May 22, 2020 11:46 amCanon .CR3
It's a known issue with CR3 format
Heerockss
Post by Heerockss »
Ok, i googled but couldnt find anything related. Sorry.
Heerockss
Post by Heerockss »
Will this be fixed in the next version? If yes, is there already a release ETA?
Heerockss wrote: Fri Jun 05, 2020 12:08 pm Will this be fixed in the next version? If yes, is there already a release ETA?
not already fixed
Heerockss
Post by Heerockss »
Will there ever be an update to fix this Issue?
Heerockss
Post by Heerockss »
Oh god i would kill for this to be fixed... ok maybe not, but its really annoying :?
dwynn
Post by dwynn »
xnview wrote: Sat Jun 06, 2020 11:37 am
not already fixed
I too am getting a black window when viewing .CR3 RAW files (from a Canon M6 Mark II, same sensor as 90D) in XnViewMP 0.96.5. I do not know how to interpret "not already fixed." Is it fixed or is it being fixed?
dwynn wrote: Fri Sep 25, 2020 12:58 pm I too am getting a black window when viewing .CR3 RAW files (from a Canon M6 Mark II, same sensor as 90D) in XnViewMP 0.96.5. I do not know how to interpret "not already fixed." Is it fixed or is it being fixed?
It's not fixed, you can use embedded image to have a preview
Heerockss
Post by Heerockss »
Still nothing? :|
Heerockss
Post by Heerockss »
Still nothing? :|
Heerockss
Post by Heerockss »
Version 1.90 released and still not fixed... :D
Heerockss
Post by Heerockss »
Still Nothing?
