Crash with JPG picture
Blackx
Post by Blackx »
after using XnView nearly flawlessly for a long time, I have come accross a file, which crashes the program. Here is it:
http://blackx.webzdarma.cz/gana-24vwsketch2.jpg
XnView could easily view this file, but after opening browser and pointing to the directory with this file, bad things happen (access violation).
The problem occurs only when "Use embedded thumbnail" is checked.
I am using last version of XnView (1.80.3), 250x100 thumbnails.
ckv
Post by ckv »
I can confirm this in XnView 1.80.3, but in the 1.82 alpha it works, :D so it looks like Pierre have fixed the problem.
Post by Guest »
Great! :)
Thanks for the reply and thanks Pierre for solving this bug "in advance" ;)
Re: Crash with JPG picture
Blackx wrote:Hello,
Ok, i'll check
Blackx wrote:Hello,
Could you send me it, i can't download it...
ckv
Post by ckv »
xnview wrote:Could you send me it, i can't download it...
What's the problem?
ps. Don't worry. I will edit the picture out! Edit: done that.
