The "resize dialogue" has all "combo boxes" arranged in one group and all "options / toggle boxes" in another group. I think it would be improved (for better understanding, for better UI and usability) when some depending settings would be arranged together:
- The option "Keep Print Size" could be integrated in the "Print size section"
- The "Resample" option has effect on the "Screen Size section"
Regards
Peter
"Resize Dialogue" - some rearrangement
- Attachments
- Clipboard-1.png (12.58 KiB) Viewed 96894 times
Re: "Resize Dialogue" - some rearrangement
Sounds like a good idea to me, Peter. Below please find the original and a draft.
Original
Draft
Notes:
Original
Draft
Notes:
- "Apply sharpen" was changed to "Sharpen"
- The checkboxes at the bottom might be also grouped in a group box but I couldn't think of a good name for the group box.
'Options'?helmut wrote: Mon Apr 06, 2020 8:35 pm Sounds like a good idea to me, Peter. Below please find the original and a draft.
Note: The checkboxes at the bottom might be also grouped in a group box but I couldn't think of a good name for the group box.
But probably no real need to group?
The more I think about it I believe that the combobox for "Standard Size" is also a part of the group "Screen size"
(And for the functionality of the combo-box: The selection of "pixel or percent settings" could also switch the "pixel and percent combo box" right of width and height.
+1Peter2 wrote: Tue Apr 07, 2020 8:53 amThe more I think about it I believe that the combobox for "Standard Size" is also a part of the group "Screen size"
Here's a draft what this would look like:
+1. Right, when selecting a predefined entry in the combobox which is in pixels, the unit should switch to pixel and the same for percentage.Peter2 wrote: Tue Apr 07, 2020 8:53 am(And for the functionality of the combo-box: The selection of "pixel or percent settings" could also switch the "pixel and percent combo box" right of width and height.
"Screen size" should become "Image size" or just "Size".
