Hello, a first-time user here...
I'm wondering whether it's possible to do my 'keywording' (using 'Categories') and subsequent searching by Categories with XnViewMP, then do the actual viewing of the search results with my default image viewer (macOS Preview), which hasn't got a keywording feature but does allow for, for instance, full-screen slide shows (of search results) and supports 10-bit colour. Or has XnViewMP a similar feature? (showing search results as full screen slide show)?
Thanks a lot for any advice!
Categorizing with XnViewMP then viewing with macOS Preview
Re: Categorizing with XnViewMP then viewing with macOS Preview
I'm using Windows :
Select the first image found, and click "View, Fulscreen" or F11. You get : next, prev, play/pause buttons at the bttom of the screen
When you move the mouse close to the top, a thumbnails ribbon (?) appears. Likewise an info panel on the right.
Use "I" to show/hide infos
Esc to close
All these features have settings ...
I don't know anything about 10-bit colour
Esc to close
Catalogage avec XnviewMP :
Thanks a lot!michel038 wrote: Wed Apr 01, 2020 11:23 am I'm using Windows :
Esc to close
PS: Thanks a lot for all the hard work and for Roger Carter's Guide, which I'm going to read now...
Peter
