REQ: XMP support
Mike2005
REQ: XMP support
Post by Mike2005 »
Photoshop writes some informations (like the lens used for RAW files converted by ACR) only to the XMP data and not in the EXIF data of a file.
Therefore the integration of XMP support in a future release of XnView (as thumbnail labels and properties tab) could be quite useful.
Mike
Re: REQ: XMP support
Mike2005 wrote:Photoshop writes some informations (like the lens used for RAW files converted by ACR) only to the XMP data and not in the EXIF data of a file.
Yes, i'll add XMP support in a future version of XnView
Carl
Post by Carl »
Thank-you for adding XMP in a future version!!
After much research and testing both Photoshop7.01/CS and XnView, I feel it would be an absolute *must* to have XMP in XnView!
So...in summary, I would like:
1. XMP implementation in XnView.
2. IPTC writing to TIFF Files in XnView.
Yes, i'll try to add soon
