No 4in1 folder for BMPs
Locked
robc
Post by robc »
Sorry for the title, I was trying to keep it short: if a folder contains ONLY .bmps (for example Windows wallpapers), the large folder with the 4 images is not created, it behaves just like an empty folder or a folder that contains only subfolders. Pierre, you must have forgot to add the "bmp" extension when checking for the presence of image files in the folder ;)...
XnView 1.82 alpha
Re: No 4in1 folder for BMPs
robc wrote:Sorry for the title, I was trying to keep it short: if a folder contains ONLY .bmps (for example Windows wallpapers), the large folder with the 4 images is not created, it behaves just like an empty folder or a folder that contains only subfolders. Pierre, you must have forgot to add the "bmp" extension when checking for the presence of image files in the folder ;)...
Really, houps :-)
Locked
