XnView MP 0.94
XnView MP 0.94
Please, don't post bugs or request in this topic!
You can download XnView MP 0.94 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: F8076341A5647D6022DE7F82CFCE7FC432C2425EC2AC366CB9D6982671F6DAD3
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: A9646941FE4173CD5DEAC2CA06704DCDED8887A4CF5352B34389DA9AC279907A
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.94:
1679: [New] Sort by EXIF date modified - viewtopic.php?t=39345
1676: [New] SQLite 3.29.0
1670: [New] Offset tool - viewtopic.php?t=37552
1669: [New] Unsharp Mask
1619: [New] Webp: Presets
1613: [New] Use Windows HEIC WIC decoder/encoder - viewtopic.php?t=39108
1612: [New] JPEG-XR export does not work - viewtopic.php?t=38401
1611: [New] Batch convert: Reorder items - viewtopic.php?t=38798
1606: [New] Automatic crop: edges selection - viewtopic.php?t=38015
1600: [New] DDS Bcn compression
1599: [New] Libjpeg 2.0.3
1596: [New] Template - part of text
1595: [New] Transfer: Copy data to Metadata
1593: [New] 'Go to x,y location'
1581: [New] XIM format - read support
1570: [New] RAW color matrix setting
1598: [New] Similar: 'only folder' setting
1657: [New] Canvas resize: position matrix - viewtopic.php?t=38776
1656: [New] Print selection - viewtopic.php?t=38753
1655: [New] Setting to start with always same size - viewtopic.php?t=38723
1654: [New] Filter: 'Apply' to validate current filter - viewtopic.php?t=38724
1653: [New] Edit IPTC: double click to add History item - viewtopic.php?t=38709
1649: [New] Edit IPTC: open lastest tab setting - viewtopic.php?t=38694
1648: [New] Folder always sorted alphabetically setting - viewtopic.php?t=35126
1646: [New] Edit IPTC: in view mode, write added - viewtopic.php?t=38713
1644: [New] Desaturate - viewtopic.php?t=38381
1642: [New] Curves: Buttons instead combobox - viewtopic.php?t=38489
1639: [New] Contact Sheet: Background image - viewtopic.php?t=38550
1638: [New] Custom params for toolbar's command - viewtopic.php?t=38396
1636: [New] Quick search in description - viewtopic.php?t=38495
1634: [New] Slideshow: in .sld, you can add folder (must ends with '\' or '/') - viewtopic.php?t=38502
1633: [New] Load slideshow .sld from XnView Classic - viewtopic.php?t=38502
1629: [New] Create new image - viewtopic.php?t=38577
1686: [Bug] Batch Convert: Output path - viewtopic.php?t=39503
1685: [Bug] webP & metadata settings - viewtopic.php?t=39479
1684: [Bug] Categories added on TIFF - viewtopic.php?t=39375
1683: [Bug] PAM CMYK1682: [Bug] Replace color - viewtopic.php?t=39012
1681: [Bug] Batch Convert: ICC not kept for PNG - viewtopic.php?t=39376
1680: [Bug] Non image files displayed before filtering - viewtopic.php?t=39358
1678: [Bug] BMP - viewtopic.php?t=39313
1677: [Bug] Catalog - rebuild thumbnails dead lock - viewtopic.php?t=39275
1675: [Bug] PSD fix alpha channel setting - viewtopic.php?t=39254
1674: [Bug] "return to browser" in fullscreen - viewtopic.php?t=39015
1673: [Bug] Resize IPTC dialog - viewtopic.php?t=39247
1672: [Bug] Companion files not copied/moved with Copy/Move to - viewtopic.php?t=39164
1671: [Bug] Category search pane - viewtopic.php?t=37779
1668: [Bug] Browser: EXIF rotation (field) doesn't update timestamp - viewtopic.php?t=38866
1667: [Bug] Change color depth & background color - viewtopic.php?t=37996
1666: [Bug] Catalog relocate - viewtopic.php?t=37644
1665: [Bug] 'Match all' + rating + categories - viewtopic.php?t=38115
1664: [Bug] Random quick slideshow shows at most ~32,000 images - viewtopic.php?t=38721
1663: [Bug] Wrong focus after returning from fullscreen - viewtopic.php?t=37727
1662: [Bug] Edit mode: File size displayed after rename - viewtopic.php?t=38432
1661: [Bug] Fusion dark theme & detail view - viewtopic.php?t=38022
1660: [Bug] Fusion dark theme - viewtopic.php?t=39122
1659: [Bug] Batch convert: Use CPU Core's - limited to last used setting - viewtopic.php?t=38669
1658: [Bug] Maximized to Fullscreen - viewtopic.php?t=38700
1652: [Bug] Edit IPTC: 'Write' & 'don't load fields' - viewtopic.php?t=38237
1651: [Bug] Search: mixing base path and parent folder - viewtopic.php?t=31366
1650: [Bug] Not possible to change shortcut for capture/import clipboard/scan - viewtopic.php?t=38673
1647: [Bug] Switching printers lets XNView MP ignore margin settings - viewtopic.php?t=38509
1645: [Bug] Batch rename: Not possible to use arrow to select item - viewtopic.php?t=37022
1643: [Bug] File listing: Invalid field name with date - viewtopic.php?t=38483
1641: [Bug] Compare: Thumbnails not always refreshed at startup - viewtopic.php?t=37955
1640: [Bug] System context menu on folder tree & DPI - viewtopic.php?t=38470
1637: [Bug] Background color of Category Sets & Actions with Dark Fusion theme - viewtopic.php?t=38594
1635: [Bug] 'Show all files (recursive)" in menu - viewtopic.php?t=38610
1632: [Bug] Batch conversion uses disabled checkbox setting - viewtopic.php?t=39209
1631: [Bug] Rename folder not possible if browsed before
1630: [Bug] Resize image/canvas presets ignore 'keep ratio' setting - viewtopic.php?t=38581
1628: [Bug] Windows: Unable to paste on root drive - viewtopic.php?t=38264
1627: [Bug] MacOSX: Multiple instance not possible - viewtopic.php?t=39177
1626: [Bug] Problem when renaming/moving files with unicode in catalog - viewtopic.php?t=36410
1625: [Bug] WebP: target file size not used - viewtopic.php?t=39155
1624: [Bug] Capture: XnView window must not be restored after a capture (multiple capture)
1623: [Bug] PSD: IPTC no correctly written
1622: [Bug] Batch Convert: Resize - Longest/shortest & percent
1621: [Bug] TIFF - viewtopic.php?t=38180
1620: [Bug] Custom labels & validation - viewtopic.php?t=39128
1618: [Bug] Replace dialog: filesize is missing - viewtopic.php?t=39138
1617: [Bug] PSD: Error when writing metadata - viewtopic.php?t=39137
1616: [Bug] Can't save 1bit into webp - viewtopic.php?t=39104
1615: [New] Compare: Tabs - viewtopic.php?t=38746
1614: [Bug] Canvas Resize: Background color not saved
1610: [Bug] Compare: color labels - viewtopic.php?t=38744
1609: [Bug] Missing time total/elapsed for video playing
1608: [Bug] Video thumbnail creation locks - viewtopic.php?t=38045
1607: [Bug] Clipboard at exit - viewtopic.php?t=25527
1604: [Bug] Search: not using sidecar - viewtopic.php?t=38967
1603: [Bug] Registry not correctly detected - viewtopic.php?t=39014
1602: [Bug] Slow GIF playback - viewtopic.php?t=39005
1601: [Bug] {MPixel} format - viewtopic.php?t=39016
1597: [Bug] Import&Sort: EXIF date always used in filename template
1594: [Bug] Crash {META:LensID}
1592: [Bug] Batch convert + "Use CPU Cores" very slow to start with 30,000 images - viewtopic.php?t=38943
1591: [Bug] Height ignored when resize 'fill' & keep ratio off - viewtopic.php?t=38921
1590: [Bug] Canvas resize - Relative - 'mm' doesn't work - viewtopic.php?t=38924
1589: [Bug] Crash in curve - viewtopic.php?t=38903
1588: [Bug] CVE-2019-12151
1587: [Bug] Remote files must not be added to recent files
1586: [Bug] Filter with rating AND color label doesnt work - viewtopic.php?t=38890
1585: [Bug] Categories partly updated after 'Edit IPTC' - viewtopic.php?t=38878
1584: [New] Batch convert: Hot folders without auto processing - viewtopic.php?t=38825
1583: [Bug] Batch convert: Preview not updated - viewtopic.php?t=38856
1582: [Bug] Thumbnail for FLV not created - viewtopic.php?t=38867
1580: [Bug] Paste clipboard problems - viewtopic.php?t=38846
1579: [Bug] SPACE can't be assigned - viewtopic.php?t=38755
1578: [Bug] Folder thumbnail not created in the right order - viewtopic.php?t=38763
1577: [Bug] If thumbnail for video is disabled, slow when checking files
1576: [Bug] Crash on rotate 180 on binary image (w=1305)
1575: [Bug] 8bits+transparency => 32bits problem
1574: [Bug] Rename overwrite file if exist (usb key)
1573: [Bug] Dead lock on ppt
1572: [Bug] No icon for .url - viewtopic.php?t=38743
1571: [Bug] iThmb format
1569: [Bug] Jxr Half - viewtopic.php?t=38679
1568: [Bug] Import categories from Windows Live Fotogallery - viewtopic.php?t=38612
Changelog 0.93.1:
1567: [Bug] Print only first page - viewtopic.php?t=38651
1566: [Bug] HEIC on Mac
1565: [Bug] Stars on preview don't change rating
1564: [Bug] Error reading TGA 16bits RLE
1563: [Bug] Exit Artist shown on NEF file
1562: [Bug] Prev/Next not working with two or more opened tabs - viewtopic.php?t=38523
1561: [Bug] Problem to move video files - viewtopic.php?t=38488
1560: [Bug] Fullscreen view mode - Focus on image lost after edit - viewtopic.php?t=38490
1559: [Bug] Contact Sheet: Folder not restored - viewtopic.php?t=38570
1558]: [Bug] SPACE key settings - viewtopic.php?t=38478
1557: [Bug] WebP 32bits & metadata - viewtopic.php?t=38514
1556: [Bug] XCF (floating pixel) crash
1531: [Bug] Linux move to trash - viewtopic.php?t=37989
1555: [Bug] Windows Save dialog, Most used formats no more at top
Changelog 0.93:
1507: [New] Space key for next picture
1506: [New] 'Add selection to Favorites' - http://newsgroup.xnview.com/viewtopic.php?t=37666
1505: [New] After 'save as', use output filename setting
1504: [New] Format option button in save dialog (Windows only)
1500: [New] SHIFT/CTRL to constraint drawing line horizontally/vertically
1543: [New] ScrollbarValue setting - http://newsgroup.xnview.com/viewtopic.php?t=33419
1540: [New] Selection grid setting - http://newsgroup.xnview.com/viewtopic.php?t=38270
1539: [New] [General/scanDone] to close or not TWAIN dialog after scan
1534: [New] Import&Sort: Video subfolder - http://newsgroup.xnview.com/viewtopic.php?t=37976
0076: [New] Batch Processing running on multiple cores - http://newsgroup.xnview.com/viewtopic.php?t=24355
1524: [New] WEBP EXIF/XMP support
1523: [New] OpenJPEG updated
1522: [New] WEBP updated
1516: [New] Settings to choose color label - http://newsgroup.xnview.com/viewtopic.php?t=38191
1515: [New] Ratio always > 0, settings added - http://newsgroup.xnview.com/viewtopic.php?t=38107
1514: [New] -clipaste
1553: [Bug] IPTC dialog: Crash 'insert from' in Edit mode
1552: [Bug] Capture (rectangle) with hotkey returns desktop
1551: [Bug] Batch convert: Description not used in 'Add Text'
1550: [Bug] Slideshow: Audio file not loaded from .sld - http://newsgroup.xnview.com/viewtopic.php?t=38427
1549: [Bug] Import&Sort: Image with no EXIF date are not imported
1548: [Bug] Batch Convert: 'Keep structure' & 'Keep parent' can't convert on same root partition
1547: [Bug] Resize presets not correctly saved/restored - http://newsgroup.xnview.com/viewtopic.php?t=38351
1546: [Bug] Crash when renaming folder in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=38380
1545: [Bug] Batch convert: Delete icon not enabled after saving script
1544: [Bug] Batch convert: Small/Large thumbnails setting not restored
1542: [Bug] XnConvert: 'Delete original' setting not saved - http://newsgroup.xnview.com/viewtopic.php?t=38355
1541: [Bug] ICNS with JPEG2000 icon - http://newsgroup.xnview.com/viewtopic.php?t=38363
1538: [Bug] Seek video by clicking on time slider bar - http://newsgroup.xnview.com/viewtopic.php?t=35144
1537: [Bug] XCF 2.10
1536: [Bug] Curves: Area to move control point too small - http://newsgroup.xnview.com/viewtopic.php?t=38336
1535: [Bug] key navigation disabled after crop - http://newsgroup.xnview.com/viewtopic.php?t=38294
1533: [Bug] Paint: Text not saved - http://newsgroup.xnview.com/viewtopic.php?t=37691
1532: [Bug] Contact Sheet: no top margin - http://newsgroup.xnview.com/viewtopic.php?t=37617
0756: [Bug] Print custom size - http://newsgroup.xnview.com/viewtopic.php?t=32327
1531: [Bug] Linux move to trash - http://newsgroup.xnview.com/viewtopic.php?t=37989
1530: [Bug] Freeze when creating thumbnail for small video files - http://newsgroup.xnview.com/viewtopic.php?t=38045
1529: [Bug] DPX 8bits load/save - http://newsgroup.xnview.com/viewtopic.php?t=38159
1528: [Bug] Language mix in dialogs - http://newsgroup.xnview.com/viewtopic.php?t=38096
1527: [Bug] Batch Convert Drag&Drop does not work when listview is enabled - http://newsgroup.xnview.com/viewtopic.php?t=38266
1526: [Bug] Open a PDF can show an error - http://newsgroup.xnview.com/viewtopic.php?t=38249
1525: [Bug] Can't drag in browser mode if there are marked files - http://newsgroup.xnview.com/viewtopic.php?t=38227
1521: [Bug] XCF dead lock
1520: [Bug] Context menu must not be shown on folder in favorite
1519: [Bug] Dead lock on mpa/m4a files - http://newsgroup.xnview.com/viewtopic.php?t=38224
1517: [Bug] Problem with icons generation, settings added (was causing some crash on older QT)
1513: [Bug] Problems when searching with 'base path'
1512: [Bug] MacOSX: UI problem with video files
1511: [Bug] IPTC keywords sorted in details view - http://newsgroup.xnview.com/viewtopic.php?t=38011
1510: [Bug] .lnk can't be viewed - http://newsgroup.xnview.com/viewtopic.php?t=37995
1509: [Bug] Batch Rename: same name but different extension - http://newsgroup.xnview.com/viewtopic.php?t=38020
1508: [Bug] Arrow keys not working in list view
1503: [Bug] Slideshow: use transition not checked after loading .sld
1502: [Bug] Batch convert: Clear input file don't work anymore
1501: [Bug] Slideshow crash
1499: [Bug] Searching by Image Width and Image Height Returns 0 Results - http://newsgroup.xnview.com/viewtopic.php?t=38100
1498: [Bug] Batch Convert: 'Source folder' not selected after load .xbs - http://newsgroup.xnview.com/viewtopic.php?t=38057
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - http://newsgroup.xnview.com/viewtopic.php?t=37755
1497: [Bug] Bad decoding of embedded comment
1496: [Bug] Crash when renaming Favorites
Changelog 0.92:
1495: [Bug] Open problem - viewtopic.php?f=62&t=37920
1495: [Bug] Switch mode - viewtopic.php?f=62&t=37916
Changelog 0.91:
1487: [New] PDF v1.4 output
1486: [New] Sqlite 2.24.0
1482: [New] Audio with slideshow - viewtopic.php?f=60&t=37463
1387: [New] Ratio field - viewtopic.php?f=60&t=37204
1384: [New] Batch convert: Back color added to convert 32bits into 24bits - viewtopic.php?f=110&t=37147
1391: [New] Autocomplete in copy/move dialog - viewtopic.php?f=110&t=37257
1478: [New] Join: Fit width or height
1475: [New] Batch resize by width or height - viewtopic.php?f=60&t=36864
1471: [New] PackJPG format (read)
1470: [New] Lepton format (read) added
1467: [New] Companion files handling - viewtopic.php?f=95&t=35508
1465: [New] HPI alpha channel supported
1464: [New] Custom title bar in browse mode - viewtopic.php?f=82&t=37446
1457: [New] Change timestamp: Increment at each file - viewtopic.php?f=82&t=37416
1456: [New] Edit colormap - viewtopic.php?f=95&t=37217
1452: [New] QtAV used on Linux/Mac for video playing/thumbnailing
1454: [New] Message before to quit - viewtopic.php?f=82&t=37380
1447: [New] More options for RAW
1439: [New] KRITA support - viewtopic.php?f=60&t=33385
1433: [New] 'Use Alpha channel' not remembered - viewtopic.php?f=95&t=34644
1432: [New] Search: Select pathname field - viewtopic.php?f=95&t=37086
1441: [New] Tooltips when drawing selection - viewtopic.php?f=60&t=37259
1427: [New] Recent quick search list - viewtopic.php?f=95&t=37201
1425: [New] Resize dialog - viewtopic.php?f=95&t=36772
1409: [New] Relative path in .sld - viewtopic.php?f=62&t=37181
1406: [New] Information for Audio/Video file - viewtopic.php?f=95&t=35843
1405: [New] Sharpen in Resize dialog
1404: [New] Autoskew in edit mode
1400: [New] IPTC dialog in view mode - viewtopic.php?f=60&t=34630
1399: [New] Setting to create descript.ion in UTF8
1493: [Bug] ICC support in compare - viewtopic.php?f=62&t=37808
1492: [Bug] JPEG2000 YCC - viewtopic.php?f=35&t=37806
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - viewtopic.php?f=62&t=37755
1490: [Bug] 'Crop, save & next' doesn't always save cropped image - viewtopic.php?f=82&t=37730
1489: [Bug] Batch convert- automatic crop - viewtopic.php?f=79&t=37782
1488: [Bug] When catalog is not used, can't save search
1485: [Bug] Save 32bits as jpeg - viewtopic.php?f=62&t=37638
1484: [Bug] Crash with 1x1 png - Thanks to Martin Orem of Binary House
1483: [Bug] TIFF with JPEG compression - viewtopic.php?f=35&t=37585
1481: [Bug] IPTC Edit: Object name not always modified on RAW - viewtopic.php?f=83&t=37441
1480: [Bug] Deselecting by CTRL key - viewtopic.php?f=62&t=37486
1479: [Bug] Batch convert: Problem when filename has $ character
1477: [Bug] Embedded comment always written in utf8 - viewtopic.php?f=62&t=37497
1476: [Bug] Batch convert: if 'delete original', steals focus - viewtopic.php?f=79&t=37328
1474: [Bug] Batch Rename: First item no more selected - viewtopic.php?f=62&t=37297
1473: [Bug] Dialog Edit curves: curve not visible if preview enabled - viewtopic.php?f=62&t=37487
1472: [Bug] Crop unavailable until change crop area manually - viewtopic.php?f=82&t=37461
1469: [Bug] Export: wepb quality widget too small - viewtopic.php?f=62&t=37482
1468: [Bug] Slow when entering on a folder with a lot of files (icon create)
1466: [Bug] Characters problem with exif label in view informations - viewtopic.php?f=83&t=37459
1463: [Bug] Edit IPTC: no hierarchicalSubject written for RAW - viewtopic.php?f=83&t=37441
1462: [Bug] Edit IPTC: EXIF:artist modified on RAW file - viewtopic.php?f=83&t=37441
1461: [Bug] Long full path on windows 10 - viewtopic.php?f=95&t=36108
1460: [Bug] Batch Convert: Hot folder, files not completly written, can't be readed - viewtopic.php?f=79&t=3743
1459: [Bug] Error reading panorama image from S9 - viewtopic.php?f=62&t=37427
1458: [Bug] Rounded value in batch resize - viewtopic.php?f=36&t=37451
1455: [Bug] Filesize in Info not changed after save - viewtopic.php?f=62&t=37319
1453: [Bug] Video thumbnail not correctly build by QtAv
1451: [Bug] Open image tab while in fullscreen on second monitor - viewtopic.php?f=62&t=35028
1450: [Bug] PDF output on Linux - viewtopic.php?f=82&t=37376
1449: [Bug] Batch convert: Preview 'after' not always loaded - viewtopic.php?f=62&t=37377
1448: [Bug] All details on info pane are missing while Fullscreen preview is active - viewtopic.php?f=95&t=3658
1446: [Bug] Join: Collage on non image files
1445: [Bug] Batch Convert: ESC before end of process
1444: [Bug] Grid settings are not saved - viewtopic.php?f=62&t=37363
1443: [Bug] When selecting file without thumbnail, should create this one first - viewtopic.php?f=95&t=36704
1442: [Bug] Folders in folder tree are expanded - viewtopic.php?f=62&t=36808
1440: [Bug] Webm support
1438: [Bug] Excluding folders in Catalog & copy files - viewtopic.php?f=95&t=36635
1437: [Bug] Batch Convert: Hot folders & subdirectories - viewtopic.php?f=82&t=37338
1436: [Bug] Included/excluded folder list - double entries possible - viewtopic.php?f=62&t=37345
1435: [Bug] Slideshow order is not being restored on opening an .sld - viewtopic.php?f=62&t=37360
1434: [Bug] Thumbnail and Image Orientation out of sync after Jpeg Lossless Rotate - viewtopic.php?f=95&t=36687
1431: [Bug] Compare: thumbnails view size - viewtopic.php?f=95&t=36954
1430: [Bug] EXIF Image width/height is not updated - viewtopic.php?f=95&t=36625
1429: [Bug] Move shortcut of file - viewtopic.php?f=95&t=36971
1428: [Bug] Name collision dialog uses old name on renaming - viewtopic.php?f=95&t=37084
1426: [Bug] Ctrl+Right Click does not select the image - viewtopic.php?f=95&t=36951
1424: [Bug] Wheel on preview change focus - viewtopic.php?f=95&t=36767
1423: [Bug] Ctrl+Right Click unselects the image in detail view - viewtopic.php?f=95&t=36950
1422: [Bug] Selection must be restored after undo - viewtopic.php?f=95&t=37102
1421: [Bug] Rating/Label on folder always cleared - viewtopic.php?f=95&t=37269
1420: [Bug] Selection with the keyboard controls is inconsistent - viewtopic.php?f=95&t=34297
1419: [Bug] Duplicate video playback - viewtopic.php?f=95&t=35953
1418: [Bug] Not responsive while opening image file - viewtopic.php?f=95&t=35057
1417: [Bug] Wrong focus after returning from image tab - viewtopic.php?f=95&t=35964
1416: [Bug] Image navigation pane shown on animated GIF - viewtopic.php?f=95&t=36012
1415: [Bug] MacOSX: copy instead of move on same partition - viewtopic.php?f=95&t=35754
1414: [Bug] Fixed ratio for selection and horizontal handler - viewtopic.php?f=95&t=36457
1413: [Bug] PDF when viewing are not skipped if ghosctscript is not installed - viewtopic.php?f=95&t=35338
1412: [Bug] Batch Convert: Delete original always use recycle bin - viewtopic.php?f=95&t=37132
1411: [Bug] Thumbnail ratio - viewtopic.php?f=95&t=33725
1410: [Bug] Batch Rename not possible on Movie - viewtopic.php?f=95&t=35923
1401: [Bug] Modified date for OpenXML format changed when creating thumbnail - viewtopic.php?f=62&t=37344
1408: [Bug] Keys in slideshow - viewtopic.php?f=62&t=37181
1407: [Bug] Favorites not sorted after adding one - viewtopic.php?f=95&t=37092
1403: [Bug] Batch Rename: 'always added' not saved - viewtopic.php?f=60&t=37332
1402: [Bug] Wrong thumbnail from catalog - viewtopic.php?f=82&t=33548
1398: [Bug] Slow search on annotations - viewtopic.php?f=82&t=37295
1397: [Bug] Annotation doesn't work, in slideshow - viewtopic.php?f=82&t=37300
1396: [Bug] Freeze when clicking on .url - viewtopic.php?f=62&t=37289
1395: [Bug] Windows default context menu use only 1 file - viewtopic.php?f=82&t=37287
1394: [Bug] Export resize for NConvert - viewtopic.php?f=79&t=37278
1393: [Bug] Thumbnail process on big files can't be interrupted - viewtopic.php?f=110&t=37182
1390: [Bug] Cancel 'Edit Favorites path' - viewtopic.php?f=62&t=37100
1389: [Bug] Print: Incorrect caption in picture collection - viewtopic.php?f=62&t=37274
1388: [Bug] Directory locked after batch convert - viewtopic.php?f=62&t=37242
1386: [Bug] Batch convert: keep folder and folder at root path
1385: [Bug] Paint: b&w, 8bits colormap are converted with bad colors
1383: [Bug] Batch convert: ICC convert doesn't work on 64bits version - viewtopic.php?f=79&t=37176
1382: [Bug] Batch convert: extension is not changed - viewtopic.php?f=79&t=37165
1381: [Bug] Image with alpha channel converted in JPEG - viewtopic.php?f=82&t=37147
Foxyrick
Re: XnView MP 0.94
Post by Foxyrick »
My weekly 'has it been updated yet' check... yes it has!
Thank you for this update - finally my folders are sorted alphabetically. It will make things so much easier for me :D
I've just sent a donation - thank you for a great application!
zzapper
Re: XnView MP 0.94
Post by zzapper »
I'm quite a new user of XnViewMP (Linux) and still learning what can be done with such a powerful program is there a summary of the improvements to MP in 0.94 rather than bug fixes?
Re: XnView MP 0.94
zzapper wrote: Mon Nov 18, 2019 10:03 am I'm quite a new user of XnViewMP (Linux) and still learning what can be done with such a powerful program is there a summary of the improvements to MP in 0.94 rather than bug fixes?
The 0.94 changelog on the first page of this thread shows changes as [New] and [Bug] ...
mrwul
Re: XnView MP 0.94
Post by mrwul »
This is just to say...
Super!
THANK you soo much !
