I don't think this is important, but perhaps these defaults would be more intuitive.
Thumbnails= 'Show filenames in thumbnail mode' unchecked (new checkbox option).
Thumbnails & Labels= Filename in label list.
XnView 1.82 alpha
Thumbnail defaults.
Re: Thumbnail defaults.
I disagree. The filename is needed for renaming and fully identifying the photo.marsh wrote:I don't think this is important, but perhaps these defaults would be more intuitive.
Strongly agree. By default "Thumbnails & Labels" should not show less than "Thumbnail", this would be confusing. Apart from the filename even 1-3 more useful labels could be added by default.marsh wrote:Thumbnails & Labels= Filename in label list.
But by default you have filename, type & dimension!!helmut wrote:Strongly agree. By default "Thumbnails & Labels" should not show less than "Thumbnail", this would be confusing. Apart from the filename even 1-3 more useful labels could be added by default.marsh wrote:Thumbnails & Labels= Filename in label list.
Are you sure ?
- When launching the browser in the Alpha the first time, I had nothing more than the filename as default label…
Re: Are you sure ?
With last alpha too?Clo wrote:Pierre
Hello Pierre!
- I use 1.82 alpha (November 1st. 2005)
If you make any update / fix, please, indicate it clearly in the thread, thanks!
- Maybe some marking off like :
…1.82.a1 1.82.a2 … should be useful ?
Re: ??
It's the same, must be checked in next betaClo wrote:Hello Pierre !
If you make any update / fix, please, indicate it clearly in the thread, thanks!![]()
