Allow to use excluded cat ONLY in categories filter
Moderators: XnTriq, xnview
fireattack
Post by fireattack »
Currently you can exclude a category by alt + click in categories filter.
However, it only works if you also choose at least another category, otherwise, it shows no result.
If I want to search for all images but the ones with category "test", I can't.
We do have that "special item" of "All", but multi-choose it together with an excluded category doesn't work.
Re: Allow to use excluded cat ONLY in categories filter
Post by michel038 »
I have no answer, but ...
:shock:
Where did you find this tip ?
I went back two years without finding anything ...
m.Th.
Post by m.Th. »
m. Th.
- Dark Themed XnViewMP 0.99.6 64bit on Win10 x64 -
fireattack
michel038 wrote: Fri Oct 04, 2019 12:19 pm I have no answer, but ...
:shock:
Just instinct learnt by using various software for years :P
fireattack wrote: Sun Sep 29, 2019 2:09 pm If I want to search for all images but the ones with category "test", I can't.
I don't understand, click on "test" category to have them
Post by michel038 »
An inelegant and very slow solution :
Give a category ( "default" or "ToDo" ) to all photos.
In Categories filter, now you can select "default" and Alt "Test" ...
